[Epicor 9] Table and Field Changes list
I'd ask your CAM and see if you can get something this way. There has to be an internal document.
-bws
Brian W. Spolarich ~ Manager, Information Services ~ Advanced Photonix / Picometrix
    bspolarich@... ~ 734-864-5618 ~ www.advancedphotonix.com
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of sysadmin@...
Sent: Monday, September 21, 2009 8:49 AM
Subject: RE: [Vantage] [Epicor 9] Table and Field Changes list
Thanks, Mark. I've already taken a look at the .df files and if there is
nothing else available, then I guess those will be the resource of choice.
I was just hoping that someone had a spreadsheet or other document listing
the changes.
_____
Mark Wonsil
Sent: Sunday, September 20, 2009 12:56 PM
> Has anyone seen a list of the tables and fields that have
> changed in Epicor
> 9, or can anyone suggest where you can obtain it? It's apparently very
> difficult to find, even for Support. For Vantage 8.03.4xx, it's very
> conveniently located right in Help within the System Overview
> topic, but for Epicor 9, that has changed and it's no longer there.
Not the easiest to read but if you look in the ClientServer\db folder under
Epicor904 folder, you will find the actual SQL statements that upgrade the
database. The files end in .df. There is one file for each level, e.g.
803-300.df, 803-400.df, etc. There are some levels that are not published
versions but they appear to be places holders. For example, there's an
803-500.df.
Mark W.
If this has been discussed previously, I apologize for the repeat.
Has anyone seen a list of the tables and fields that have changed in Epicor
conveniently located right in Help within the System Overview topic, but for
Regards,
Scott
> changed in Epicor
803-500.df.
Mark W.
the changes.
_____
Mark Wonsil
> changed in Epicor
803-500.df.
Mark W.
