Epicor 904.503b xmls after print preview staying in client folde
I dont know about 9.05.600, but it is still "broke" in 9.04.506a...
--- In vantage@yahoogroups.com, "Randy" <rraub@...> wrote:
> Does anyone have any information as to whether this was corrected in 9.05?
> Thanks
> Randy Raub
> Senior Software Support Analyst
> --- In vantage@yahoogroups.com, Troy Richman <troyr@> wrote:
> > My last update was that the issue is with development. They have not yet released a SCR.
> > Troy
> > From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of howecorp
> > Sent: September-29-09 10:29 AM
> > Subject: [Vantage] Re: Epicor 904.503b xmls after print preview staying in client folder
> > Does anyone know if there is an SCR (& resolution) on this?
> > --- In vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>, Troy Richman <troyr@> wrote:
> > > This is a known bug in Epicor 9.
> > > Troy
> > > From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>] On Behalf Of advantage@
> > > Sent: September-29-09 9:02 AM
> > > To: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>
> > > Subject: [Vantage] Epicor 904.503b xmls after print preview staying in client folder
> > > Why would a client's XMLs be staying in their EpicorData\Reports\(login)
> > > folder after printing even if the Archive Period was at 0 days. We have a
> > > slew of xmls sitting in several client folders. This didn't happen on V8?
> > > Thank you.
I have a company, call it Company 1. I am creating a new Company, call it Company 2.
I need all parts in Company 1 copied over to Company 2.
I spent a bit of time on the phone with Epicor today getting Sonic working. Once I did, I marked a few parts in Company 1 as "global".
and waited. Nothing happened.
I called again, and was told that the part has to exist in Company 2 first, then you go in for each part and link to the part in Company 1.
Do I completely misunderstand what is happening here?
All I want is that all parts from 1 copy over to 2. No further connection, no need to update one when the other changes; the 2 companies need never speak to each other again.
Is this possible without spending thousands on custom programming?
Tony, the two safe ways I can think of doing this are by custom
programming or service connect workflow.
A service connect workflow could be created using a spreadsheet of the
parts you want to copy (you may not want to copy all of them) and a
service connect workflow that generates the new parts in the new company
from the old company. The part plant information also has to be
generated so that also needs to be taken into consideration as well as
any transformations to the reference files (Part Class, Product Group,
Tax Category, G/L account, etc).
A custom program could do the same as the SC workflow but would probably
run faster.
In any case, you are talking a few bucks.
Charlie Smith
Smith Business Services / 2W Technologies LLC
www.vistaconsultant.com <http://www.vistaconsultant.com/> /
www.2WTech.com
Of Tony Hughes
Sent: Monday, September 28, 2009 2:15 PM
Subject: [Vantage] Pushing parts in to New Company
it Company 2.
I think you should try Service Connect
> Thanks
Tony,
I concur with Charlie. Service Connect can take some time to run.. More columns and more rows means more time. How many parts are you copying?
Lorraine Aiello
Senior Programmer Analyst
Gloucester Engineering Co., Inc.
aiello.l@...
Sent: Monday, September 28, 2009 2:59:37 PM
Subject: RE: [Vantage] Pushing parts in to New Company
Â
run faster.
Charlie Smith
www.vistaconsultant .com <http://www.vistaconsultant.com/> /
www.2WTech.com
From: vantage@yahoogroups .com [mailto:vantage@yahoogroups .com] On Behalf
Of Tony Hughes
To: vantage@yahoogroups .com
it Company 2.
When I did my part import with Service Connect it took me 1K parts per hour.
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Lorraine Aiello
Sent: Monday, September 28, 2009 3:39 PM
Subject: Re: [Vantage] Pushing parts in to New Company
Tony,
Lorraine Aiello
aiello.l@...
Â
run faster.
Charlie Smith
www.2WTech.com
Of Tony Hughes
it Company 2.
Just to refine something here.
In Vantage, you can mark a Part as Global. This will copy the part information to GlbPart. You can then link that GlbPart from the parent company to a child company. MultiCompany will then, via SonicMQ, keep the child in sync with the parent. In addition, the Part in the child company isn't editable/maintainable, except for those fields you choose not to send between the companies via the Global Table config.
That's the intended scenario that the linking parts between companies is for.
If you don't want them to update after that (i.e. you intentionally want to keep them from updating), you would need to set the Global Lock flag in the child company for each Part.
If you just want to load Part information from one company to another, and don't want the default updating behavior, then you really just want to export the Part information from one company and load it via Service Connect or a custom program.
Epicor will sell you a Part Import Service Connect workflow for $2K or something like that which is pretty reasonable. It is the simplest of the standard 'master' data to write SC workflows against (compared to say a BOM which is pretty complex to deal with) so you can also roll your own if you have the full SC license.
All data in companies in Vantage, for the most part, stand alone.
-bws
Brian W. Spolarich ~ Manager, Information Services ~ Advanced Photonix / Picometrix
    bspolarich@... ~ 734-864-5618 ~ www.advancedphotonix.com
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Tony Hughes
We wrote an import using Microsoft SQL Server Integration Services (SSIS) utilizing the Part Web Service.
Bob
Tony,
The simplest and fastest way to migrate the data would involve just a
few steps. First clone your live DB then run a simple SQL Update
statement on the clone to change the company ID to the new company
making sure to change all of the supporting tables as well. Then use
an ETL tool to import the parts back into the live DB. If you are
running SQL Server you can use the native DTS service. If you run
Progress you can use any number of third party ETL tools including
some that are open source.
Regards,
Michael
Michael Barry
Aspacia Systems Inc
866.566.9600
312.803.0730 fax
http://www.aspacia.com/
This email, and any attachments thereto, is intended only for use by
the addressee(s) named herein and may contain legally privileged and/
or confidential information. If you are not the intended recipient of
this email, you are hereby notified that any dissemination,
distribution or copying of this email, and any attachments thereto, is
strictly prohibited. If you have received this email in error, please
immediately notify me by telephone and permanently delete the original
and any copy of any email and any printout thereof.
> call it Company 2.
> Thanks
Thank you.
Troy
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of advantage@...
Thank you.
I have 9.04.504B in a test environment and I'm seeing the same behavior.
Gerry
advantage@...
Sent: Tuesday, September 29, 2009 12:02 PM
client folder
Thank you.
Did you upgrade or is this a new install?
advantage@...
client folder
Thank you.
> Troy
> Thank you.
> Troy
> Thank you.
upgrade
Gerry Loranger
Sent: Tuesday, September 29, 2009 1:26 PM
Subject: RE: [Vantage] Epicor 904.503b xmls after print preview staying in
client folder
From: vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com
[mailto:vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com] On
Behalf Of
advantage@wcoil. <mailto:advantage%40wcoil.com> com
To: vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com
client folder
Thank you.
Troy
--- In vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>, Troy Richman <troyr@...> wrote:
> Troy
> From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>] On Behalf Of advantage@...
> Thank you.
I have used the engineering workbench to import parts.
The catch is, that it only will import the part number, description, and
type (M or P).
This is done by creating a part, assign a revision, check it out to the
workbench. Then get details - >import BOM. The BOM is a CSV file with the
fields Part number, Description, Type, and Qty. After you import, checkin
the revision. Delete the part that you used to do the import and work with
your new parts by some of the "Macro programs" to update groups of files.
Good luck.
Bruce Larson
Bruce.larson@...
www.altertechpartners.com
Tony Hughes
Sent: Monday, September 28, 2009 1:15 PM
Company 2.
Randy Raub
> Troy
> > Troy
> > Thank you.
