You need to be looking at the Process tab, not the "application" tab on the
task manager.
The "Application" is not responding because the application you see is not
actually doing anything, it's just a drapery hanging up to make the window
look pretty while all the work is going on in the background.
nustepvantage
Sent: Thursday, June 09, 2011 5:29 AM
Subject: [Vantage] Re: Epicor 904 Schema Change Freezing
Thanks for the responses.
In the task manager ProWin32.exe is running and says it is not responding.
Memory usage steadily increases and CPU usage gets close to 100%. The
database bi file also grows. Once I just let the schema change application
go and it eventually stopped on its own. When I did this the bi file grew to
over 2 GB in size. I think it may have stopped when it ran out of memory.
Also, during phase 1 of the process when the schema change program scrolls
through the database tables and fields loading the table definitions it
always gets hung up early in the process usually stopping with tables
beginning with the letter A.
David
task manager.
nustepvantage
David
--- In vantage@yahoogroups.com, Waffqle <waffqle@...> wrote:
> Are you sure it's locking up and not just taking forever? How much
> time have you given it? That one does take a while.
> On Wed, Jun 8, 2011 at 4:58 PM, nustepvantage <dpfiester@...> wrote:
> > Hi All,
> > I have a test VMWare virtual machine running Windows 2008 Server 64
> > bit that has Epicor 904.507A running Progress. I am trying to load a
> > backup copy of a Progress Vantage 803.409C database and convert it
> > to 904. When I attempt to run the change schema program it always
> > locks up during phase 1 of the schema change process when the program is
loading table definitions.
> > I truncated the bi file after I restored my 409C database to it
> > thinking that was the problem, but I still can't get beyond the
> > loading of table definitions. So far tech support hasn't been much
> > help. Has anyone in the group had this problem before?
> > Any help would be greatly appreciated.
> > Thanks,
> > David Pfiester
> > NuStep, Inc.
> > 734-418-1850
> *Waffqle Driggers*
> *High End Dev, System Design, Profit Drinking
> *:: 904.962.2887*
> *:: waffqle@...*
> *:: NO FAXES*
