Hello,
I have a question. our sys admin need change ip address of database. what I need update in the app server to point to the right database server.
thanks,
Eddy
Hello,
thanks,
Eddy
The IP address shouldn’t matter assuming you are in a domain and using DNS
Hello,
yes, i think we use dns name for the database. do you know where put the dns name in the app server console. when i go to the database in the app server, i did not find in the configuration.
thanks,
Eddy
Just curious which version you’re working with.
The topic looks like it’s E9 but version in posts is E10.
If E9 - Progress or SQL?
If E9/Progress then… I’m thinking I did run into a couple of “gotchas” after changing the IP address on a server but… that was a long time ago. I can’t remember any details now.
it is SQL.
thanks,
Eddy
Hello,
I found it. it is long time ago. I did not remember. it is odbc dns name. just need open the odbc. and reconfigure the right database. it is ok.
regards,
Eddy
