Epicor 905607A Upgrade
We just upgraded to 607A and had the same issue with our Customized reports. The database source location had to be reset to point correctly.
Miguel Santillan
ERP Administrator
Compass Manufacturing Services
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of John Driggers
Sent: Monday, December 12, 2011 8:04 AM
Subject: Re: [Vantage] Epicor 905607A Upgrade
Did you clone your test from production?
If so, it sounds like you may have forgotten to update your system agent.
On Mon, Dec 12, 2011 at 10:57 AM, Chris Thompson <chriselectrix@...>wrote:
> Does it work if you go into System Monitor and Print Preview from there?
> Clutching at straws - its not an older version of Crystal Runtime or
> anything simple is it?
> And all apps are running and available?
> From: "dsecco@..." <dsecco@...>
> Sent: Monday, 12 December 2011, 15:36
> Subject: [Vantage] Epicor 905607A Upgrade
> We've recently started experiencing an odd issue with our test
> enivornment of 905607A.
> When trying to run a report, clicking the 'Generate Only' or 'Print
> Preview' buttons, the result is not a report appearing on the screen,
> but a statement saying "Report submitted for Print Preview" or "Report
> submitted for Generation."
> Anyone have any ideas why the reports would not be showing up?
> Thanks.
*John Driggers*
*High End Dev, System Design, Profit Drinking
*:: 904.962.2887*
*:: waffqle@...*
*:: NO FAXES*
We've recently started experiencing an odd issue with our test enivornment of 905607A.
When trying to run a report, clicking the 'Generate Only' or 'Print Preview' buttons, the result is not a report appearing on the screen, but a statement saying "Report submitted for Print Preview" or "Report submitted for Generation."
Thanks.
Â
Clutching at straws - its not an older version of Crystal Runtime or anything simple is it?
Â
Â
Thanks.
> of 905607A.
> for Generation."
> Thanks.
*John Driggers*
*:: 904.962.2887*
*:: waffqle@...*
*:: NO FAXES*
Check the SystemTaskAgent and make sure the settings are correct, with
correct port numbers, and correct EpicorData and Epicor905\Server locations
being correct as well.
Also, check the System Monitor to see if they get printed or just end up in
the Scheduled queue. Also check to see if they end up with the "error"
message that there were no records selected, which won't output a report but
will be listed as successfully running in some cases.
dsecco@...
Sent: Monday, December 12, 2011 10:37 AM
of 905607A.
Generation."
Thanks.
