# Epicor Application unable to open
**URL:** <https://www.epiusers.help/t/epicor-application-unable-to-open/76569>\
**Category:** Epicor ERP 10\
**Tags:** application, dashboard, e10, epicor\
**Created:** [March 13, 2021, 5:25am UTC](https://www.epiusers.help/t/epicor-application-unable-to-open/76569 "2021-03-13T05:25:57Z")\
**Posts on this page:** 1\
**Showing post:** 6
<div class="post-metadata">
**Author:** ![gpayne](https://www.epiusers.help/user_avatar/www.epiusers.help/gpayne/32/55751_2.png) [@gpayne](https://www.epiusers.help/u/gpayne)\
**Post date:** [September 14, 2021, 4:23am UTC](https://www.epiusers.help/t/epicor-application-unable-to-open/76569/6 "2021-09-14T04:23:44Z")
</div>
@Henry_Burke I have separated background processing and use three task agent because @aidacra says so below. This means you can restart the printing appserver or task agents without users knowing. In addition to the event viewer info below. I also have a sql job that looks for Immediate run requests over X minutes and emails support.
> [@Epicor ERP 10.1 Task Agent Configuration Implementation Options](https://www.epiusers.help/t/epicor-erp-10-1-task-agent-configuration-implementation-options/38378):
> I’m not going to wade into why background processing can stop executing as that is a huge topic that is beyond what could be reasonably covered in one post–I’ll be discussing it throughout a number of sessions at Insights this year-- but I wanted to provide some context regarding taskagent configurations in 10.1. Epicor ERP 10.1+ allows for up to three taskagent configurations per transactional database so that if taskagent1 stops for whatever reason, taskagent2 and taskagent3 can still process…
From the link above^^^
There is a topic within the TaskAgent Configuration help that discusses how to setup notification when a taskagent stops processing/throws an error–I know that people have used that same trigger to automatically restart the taskagent service\* so that it is addressed without manual intervention.
\*In 10.1.600, we have a new command line interface for the taskagent where just a taskagent configuration can be restarted instead of the entire service.
_[View the full topic](https://www.epiusers.help/t/epicor-application-unable-to-open/76569)._
