Hello,
I need help automating a report process in Epicor. The current steps involve manually refreshing the Lead Time General (INVAL, TWC) module, copying the data, and pasting it into a specific Excel template. Afterward, the file is saved with a dynamic name format.
Here are the steps:
- Open the Lead Time General (INVAL, TWC) module.
- Hit the Refresh button.
- Right-click anywhere in the table and select the Copy All option.
- Paste the data into the Lead Time tab in the provided Excel template.
- Save the file into the same folder each day
Is there a way to automate this process, so the data is extracted, copied to the template, and saved without manual intervention? Ideally, Iād like to either press a single button or have it run automatically at a specific time each day.
If anyone has experience setting up something similar or knows of a solution, your input would be much appreciated!
