Epicor configurator cost sheet
good morning ,
just I need a knowledge in the Epicor configurator cost sheet .
if there is a document or a course that can support it will be a great for me thanks
@alex.fahmy I’m not sure what you mean, as the configurator itself does not have a cost sheet. It can alter a method’s operations so that the Quote Worksheet (costing data) is correct for a quote. It uses a combination of document rules and method rules, both of which can be found in the TechRef PDF for the Configurator. It contains all you need to know about the configurator and con be downloaded from the EpicWeb website for your version.
