Epicor Data Mapping QuickShip
Now that there is a few version deployed for QuickShip since the addition of the Epicor Data Mapping. Has any one seen how it works or any documentation on how it is supposed to work. I dont see field from Epicor in the source.
Thanks in Advance if anyone has documentation that they can share it would be wonderful.
I have no idea how it works because we didn’t end up needing to use it yet, but I think it uses XML files to pass the data back and forth.
Did you use epicor consultants to implement it?
Epicor hasn’t published anything yet. Still “Under Construction”
No we have not implemented it. We have never used it. We have been with QuickShip since version 2 of manifest. We are trying to remove some sql views and possibly thought this would help. To remove some complexity on our International Invoices.
If you can get ahold of Doug Taplin at epicor, I believe he could help you.
That’s who you need. He’s the QS expert. That’s who we worked with.
