Epicor Document type filter by application
I am new to document types and have created a few. ex. CustPO, APInv, and TaxExempt. Now when I go to attach a customer PO to an order, all 3 document types show up. How do I filter the document type to just the table that it is valid for. I expect a situation where I have many document types used across the environment. and situations where it might be appropriate to have more than one document type on a given record. ex. an OrderHed record might have a CustPO, and another one for special instructions, and another for something else. I don’t want the user to be bothered with all the other non-OrderHed related document types. Is there a way to do this without a BPM?
You want to use Document Type Control to assign Tables to the Document Type
It looks like if document type controls are not used on any type, that type is available everywhere. Would that be correct?
Thank you jkane!
Yes, I believe that is correct. If you set one Document Type to a table, that removes it from all other tables.
Thanks again. This will help me with document type planning.
