Epicor error message when approve ABOM
Thank you Greg.
In the main appserver there was a stuck process sending.
I didn’t look at that server since I have all the engineerings connected to the EngAppServer.  I guess everything still goes through main.
Sent: Tuesday, August 04, 2015 2:23 PM
Subject: [Vantage] RE: Epicor error message when approve ABOM
I would look for a busy appserver that is stuck.  If none then look in SQL Activity monitor for a process with a wait time or suspended that could be locking the record.
Sent: Tuesday, August 04, 2015 5:13 PM
To: 'vantage@yahoogroups.com'
Subject: [Vantage] FW: Epicor error message when approve ABOM
We are getting a 4GL Stop error when you try to check in MOM through Eng WB.  I went base form and same scenario.
EPICOR is at lunch, keep on getting message center.  Is there a setting I can adjust?
Lock wait timeout of 180 seconds expired (8812)
[15/08/04@12:46:15.861-0700] P-013960 T-012608 1 AS -- ** ABL Debug-Alert Stack Trace **
[15/08/04@12:46:15.861-0700] P-013960 T-012608 1 AS -- --> copyECOAttachments bm/bmm10-gd.p (D:\Epicor905\Server\bm\bmm10-gd.r) at line 34230
[15/08/04@12:46:15.861-0700] P-013960 T-012608 1 AS --     checkInRev bm/bmm10-gd.p (D:\Epicor905\Server\bm\bmm10-gd.r) at line 32261
[15/08/04@12:46:15.861-0700] P-013960 T-012608 1 AS --     doCheckInRev Server/bo/EngWorkBench/EngWorkBench.p (D:\Epicor905\Server\bo\EngWorkBench\EngWorkBench.r) at line 82485
[15/08/04@12:46:15.861-0700] P-013960 T-012608 1 AS --     CheckIn Server/bo/EngWorkBench/EngWorkBench.p (D:\Epicor905\Server\bo\EngWorkBench\EngWorkBench.r) at line 71518
[15/08/04@12:46:15.861-0700] P-013960 T-012608 1 AS --     CheckIn bo/EngWorkBench/Sink.p (D:\Epicor905\Server\bo\EngWorkBench\Sink.r) at line 3303
CONFIDENTIALITY NOTICE
The information contained in this communication, including attachments, is privileged and confidential. It is intended only for the exclusive use of the addressee. If the reader of this message is not the intended recipient, or the employee or agent responsible for delivering it to the intended recipient, you are hereby notified that any dissemination, distribution or copying of this communication is strictly prohibited. If you have received this communication in error, please notify us at 727-578-6280 and immediately delete the communication.
