Epicor Everywhere Framework EWA to run MES?
I just wanted to close this question out with the answer I got from support. Yes you can run MES over EWA, you just need to be on .700 for it to work and use the correct license type.
http://yourdomain.com/syslogin.aspx Return=menu.mes.mesmenu.aspx?LicenseType=MES
Works great!
Regards,
George Hicks
--- In vantage@yahoogroups.com, "pcivantage" <vantagegroup@...> wrote:
> Hello Group;
> We have EWA running, which is awesome by the way, and I want to run MES over HTTP. Does anyone know the mod to the URL or file to change for MES?
> URL is http://domain.com/EWA
> Can you run an MES station over EWA?
> Any help appreciated. I will call support Tuesday and post if no one has a suggestion.
> Regards,
> George Hicks
> Stadco
Hello Group;
Regards,
George Hicks
Stadco
I believe you can't
On Sep 3, 2012 2:46 AM, "pcivantage" <vantagegroup@...> wrote:
> Hello Group;
> suggestion.
> Regards,
> George Hicks
> Stadco
