Here are a few new Epicor Ideas submitted by some of my colleagues for ECM:
DocuSign signed copy needs to be added to Kinetic attachments:
When a DocuSign signature is added to an ECM document, there is a layer called View Signed. The attachment of this file to Kinetic will not bring this annotation layer to Kinetic.
https://epicor.ideas.aha.io/ideas/ECM-I-1340
Search menu -Search for dates before 1st of Month - ECM - make 1st of Month or end of month as variable
Make variables for End of Month and Start of Month, include a math function that allows the user to indicate -1 or any number. The search would show documents that that are from last month as Invoiced or Due Date.
https://epicor.ideas.aha.io/ideas/ECM-I-1341
Math Task Specific to Dates
Currently, the Math Task allows for the addition or subtraction of days, hours, months and date difference calculations. Unfortunately, there is no way to account for non-working days such as weekends and holidays, as applicable. There is a need to be able to incorporate these non-working days into these calculations so that notifications, ShipBy Dates, Due Dates, etc. would be accurate as far as when they are actionable.
The idea to resolve this would be to create a separate task designed specifically for date handling that can reference a calendar to then account for these non-working days. Ideally, ECM would be able to reference the Production Calendar from within Epicor so that it is maintainable from one spot. It would also be beneficial if it was possible to choose which calendar to use within the task as different workflows may have different purposes to align with different calendars. Lastly, it may also be beneficial to have a user defined calendar within ECM as Epicor may not be an option for some of this.
https://epicor.ideas.aha.io/ideas/ECM-I-1342
Please vote!! Thank you!!
