Where can I find the Epicor Kinetic list of all transaction codes used for all modules? example MFG-STK = Manufacturing Receipt to Stock.
Epicor has an ‘Inventory Transactions Technical Reference Guide’ that lists them all. You can find it on EpicWeb.
I put together a simplified document that lists them and gives a basic description, without as much technical detail. It is attached.
Epicor Transaction Types.pdf (104.7 KB)
Thank you very much for the information and attachment.
Andrew, When I went through the information you sent, two transaction codes / types I did not see on the sheet quickly. They are UKN-STK and MTL-STK. The instructions I am reading from Kinetic Inventory Management user guide version 2023.1 to perform certain tasks call out to use these codes / types. Is Epicor slow in keeping information up to date?
I don’t believe that Epicor actually uses the TranType codes UKN-STK or MTL-STK. Instead, they use STK-UKN and STK-MTL with a negative transaction quantity.
