There is a lot more to it than that.
I would never suggest doing what you are suggesting, using different drives in the same RAID array can be devastating sometimes, the only way that would even slightly work is if you replaced 1 disk at a time with one that is the same size otherwise it can get messy. Plus, doing 2 drives at a time can lead to corruption because the mirrors and striping don't always line up just right, rebuilding one disk at a time is the only way to make sure everything is completely accurate.
You could try it this way..... install 2 SSDs as their own RAID, then you can turn everything related to Epicor off, copy everything from the E drive to the new drive, then rename the new drive to E after making E something else.
But in general, I prefer to just redo an installation if I am making that kind of change.
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Chris Thompson
Sent: Wednesday, May 16, 2012 3:38 AM
Subject: Re: [Vantage] Re: Epicor Performance.
Hi All
Our Epicor server has 4 drives that make up the drive that holds all of the Epicor data.
They show as being double the size of a normal drive, then in raid so are copied to the other pair of drives.
The disks are 136GB I think.
My computer shows up as C = 136GB, D = 136GB E = 273GB, but there are 8 drives in the server so they are all in raid.
If we wanted to try some SSDs for the E drive, would it just be a case of e.g. finding the mirrored pair, remove them, install 2 x SSDs in their place, let the system run for a whole so all of the data from the normal drives gets copied across to them, then do the same with the normal drives (remove them and swap them with SSDs)?
Or is there a lot more to it than that?
Thanks.
Sent: Tuesday, 15 May 2012, 18:37
Subject: RE: [Vantage] Re: Epicor Performance.
With a split install would I be looking to run that metric against our
Epicor app server or the sql server?
Joshua Giese
CTO
920.437.6400 Ext. 337
_____
Of Vic Drecchio
Sent: Tuesday, May 15, 2012 10:12 AM
Start --- RUN --- Perfmon
http://www.computerperformance.co.uk/HealthCheck/Disk_Health.htm
http://adminfoo.net/2007/04/windows-perfmon-top-ten-counters.html
Behalf Of
McMullen, Travis
Sent: Tuesday, May 15, 2012 11:09 AM
Is there an answerbook on how to get to and configure Perfmon? I don't
know if I remember how to access it...
Travis L. McMullen
ERP Specialist
ComSonics, Inc.
Harrisonburg, VA 22801
Phone: 540-434-5965 x1274
Toll Free: 1-800-336-9681 x1274
Mobile: 540-435-1920
Fax: 540-434-9847
E-Mail: tmcmullen@... <mailto:tmcmullen%40comsonics.com>
On Tue, May 15, 2012 at 11:04 AM, John Driggers <waffqle@...
<mailto:waffqle%40gmail.com>
<mailto:jose%40josecgomez.com>
<mailto:jgiese%40wisconsinconverting.com> <mailto: <mailto:%0b>
a
<mailto:vantage%40yahoogroups.com> <mailto:
<mailto:waffqle%40gmail.com> <mailto:
<mailto:vantage%40yahoogroups.com> <mailto: <mailto:%0b>
<mailto:waffqle%40gmail.com> <mailto: <mailto:%0b>
<http://groups.yahoo.com/group/vantage/files/> <
<mailto:waffqle%40gmail.com> *
No virus found in this message.
Checked by AVG - www.avg.com
Version: 2012.0.2176 / Virus Database: 2425/5000 - Release Date: 05/15/12
Hi All
Thanks.
Joshua Giese
CTO
_____
Of Vic Drecchio
Behalf Of
McMullen, Travis
Travis L. McMullen
ERP Specialist
ComSonics, Inc.
Fax: 540-434-9847
> Perfmon.<mailto:tmcmullen%40comsonics.com> >wrote:
> Just load it up and do a 'right click > add counter'. It's a fairly long
> list to sort through, but it's in there. Once you set it up with all the
> counters you want, you can save the layout for future reference.
> On Tue, May 15, 2012 at 11:02 AM, McMullen, Travis
> <tmcmullen@... <mailto:tmcmullen%40comsonics.com>
>length
> > I should probably know this, but where can I view the disk queue
> forbut
> > E9? I thought it was in the Progress Explorer Tool for Vantage 8.03,
> I<mailto:tmcmullen%40comsonics.com>
> > can't find it in E9.
> > Travis L. McMullen
> > ERP Specialist
> > ComSonics, Inc.
> > Fax: 540-434-9847
> > On Tue, May 15, 2012 at 10:31 AM, John Driggers <waffqle@...
> wrote:length.
> > > I'm with Vic here.
> > > If you're only going to watch one metric, watch your disk queue
> > Ifis
> > > it starts getting high, either you don't have enough disk IO, your
> system
> > > isn't caching properly or something. Obviously, a more holistic view
> > > preferable. That said, queue length is probably the closest thing toan
> > > 'Epicor Performance' metric.<mailto:vic.drecchio%40swepcotube.com>
> > > On Tue, May 15, 2012 at 10:18 AM, Vic Drecchio
> > > <vic.drecchio@... <mailto:vic.drecchio%40swepcotube.com>
>wrote:My
> > > > Solely using your CPU as a metric for performance isn't feasible,
> IMO.
> > > > When you're talking transactional, you need to also focus on I/O.
> > > serveris
> > > > is 5 years old and rarely creeps above 25% utilization. My server
> anRAM,
> > > > antique comparatively to today's array of options. But it works.
> > CPU<mailto:vantage%40yahoogroups.com>
> > > > and I/O are all good benchmarks. Use PerfMon on your server if you
> > don't
> > > > already. You can add all sorts of angles to view your utilization.
> > Behalf<mailto:vantage%40yahoogroups.com>
> > > > Of Chris Thompson
> > > > Sent: Tuesday, May 15, 2012 9:58 AM
> > > > Subject: Re: [Vantage] Re: Epicor Performance.doesnt
> > > > Our one box never peaks (rarely for a few seconds) over 15%CPU and
> the
> > PF
> > > > use never goes about 7GB.
> > > > I dont know why they demand all of this memory and CPU when it
> > use<mailto:waffqle%40gmail.com> <mailto:waffqle%40gmail.com>
> > > > it.
> > > > From: John Driggers <waffqle@...
> > > > Sent: Tuesday, 15 May 2012, 14:40on
> > > > We've always run our system on one box and generally suggest it to
> > > others.
> > > > Outside of 2-3 very large sites or people that are trying to run
> > > antiquelimits
> > > > hardware, I've never seen anyone that was really pushing the
> of<mailto:jose%40josecgomez.com>
> > > > their server.
> > > > Bad BPMs, BAQs, configs, etc can drag things down pretty fast. But
> once
> > > > they are sorted out, you usually see that processing time is split
> > 70/30
> > > > client/server --often even more lopsided.
> > > > Setting up client caching and network compression and such will
> almost
> > > > always net you more than tinkering with your server. When I did my
> > tests
> > > > for network compression, I saw processing time cut in half on
> average.
> > > > On Tue, May 15, 2012 at 9:15 AM, Jose Gomez <jose@...
> > <mailto: <mailto:%0b>system.
> > > > jose%40josecgomez.com> > wrote:
> > > > > Hardware is cheap, you can get all the bells and whistles you'd
> ever
> > > want
> > > > > for a fraction of what it would cost you to change your ERP
> > > > > Epicor has its performance issues but overall works fine ifis
> > configured
> > > > > correctly, the truth is that as a developer I can understand why
> they
> > > > have
> > > > > some of the speed issues that they have, the way the application
> > > > written<mailto:jose%40josecgomez.com>
> > > > > is made to be flexible and extremely customizable which means
> > > everything
> > > > > has to be built on the fly or Just In Time, I'd challange you to
> > find a
> > > > > product that is as flexible and has no speed issues.
> > > > > *Jose C Gomez*
> > > > > *Software Engineer*
> > > > > *checkout my new blog <http://www.usdoingstuff.com> *
> > > > > *T: 904.469.1524 mobile
> > > > > E: jose@... <mailto:jose%40josecgomez.com>
> > > > > http://www.josecgomez.com<mailto:jgiese%40wisconsinconverting.com>
> > > > > <http://www.linkedin.com/in/josecgomez> <
> > > > > http://www.facebook.com/josegomez>
> > > > > <http://www.google.com/profiles/jose.gomez> <
> > > > http://www.twitter.com/joc85
> > > > > <http://www.josecgomez.com/professional-resume/>
> > > > > <http://www.josecgomez.com/feed/>
> > > > > *Quis custodiet ipsos custodes?*
> > > > > On Tue, May 15, 2012 at 9:05 AM, Joshua Giese <
> > > > > jgiese@...
> > > jgiese%40wisconsinconverting.com>flexible
> > > > > wrote:
> > > > > > Indeed there are, but what's the lesser of two evils for the
> number
> > > of
> > > > > > features and customizability that Epicor offers, that is the
> > > question.
> > > > > > Despite all the pain it causes us, it's undeniable how
> ittends
> > > is.
> > > > As
> > > > > > with any large software that covers an end-to-end spectrum of
> > > business
> > > > > > functions you have to expect bugs and bloat it's how Epicor
> > tohelp
> > > > > > handle the issues that seems to be more of a problem. Their
> > > development
> > > > > > team seems rather lackadaisical about coding consistency and
> naming
> > > > > > convention across their framework. I'm sure turnover doesn't
> > > thatusing
> > > > > > much either. But I digress..
> > > > > > Back to performance, what success have people had with not
> athat
> > > > split
> > > > > > install and performance gains? I've heard from consultants
a
> > > samemeasurable
> > > > > > box install seems to increase performance by a decent
> > > > amount.<mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com>
> > > > > > Can anyone validate that?
> > > > > > Joshua Giese
> > > > > > CTO
> > > > > > _____
> > > > [mailto:vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com>
> > On<mailto:vantage%40yahoogroups.com>
> > > > Behalf
> > > > > > Of Chris Thompson
> > > > > > Sent: Tuesday, May 15, 2012 7:36 AM
> > > > > > Subject: Re: [Vantage] Re: Epicor Performance.(?)
> > > > > > There are other ERP Manufacturing software out there though
> > > > > > From: Joshua Giese <jgiese@...
> > > > jgiese%40wisconsinconverting.com><mailto:vantage%40yahoogroups.com>
> > > > > > <mailto:jgiese%40wisconsinconverting.com> >
> > > > <mailto:vantage%40yahoogroups.com>getting
> > > > > > Sent: Tuesday, 15 May 2012, 12:12
> > > > > > Because it's not a perfect world and in the mean time I'm
> > > > peopleis
> > > > > > coming after me all the time because Epicor is too slow. "Such
> > > > life" Ifixes
> > > > > > suppose... I don't hold out that there will be significant
> in<mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com>
> > > > > > performance gains before these clients need to retire anyways
> > > > > > Joshua Giese
> > > > > > CTO
> > > > > > _____
> > > > > > Behalf
> > > > > > Of Chris Thompson
> > > > > > Sent: Tuesday, May 15, 2012 3:54 AM
> > > > <mailto:vantage%40yahoogroups.com>should
> > > > > > Why does everyone insist on upgrading hardware etc when it
> > beMemory
> > > > down
> > > > > > to Epicor to write a 'smoother' package that isnt so HD /
> > > heavy.<mailto:waffqle%40gmail.com>
> waffqle%40gmail.com<mailto:vantage%40yahoogroups.com>
> > > > <mailto:vantage%40yahoogroups.com>probably
> > > > > > Sent: Monday, 14 May 2012, 15:29
> > > > > > I've talked to a few people that are/were using them. By all
> > > accounts,
> > > > > > they're every bit as fast as they claim to be.
> > > > > > That said, unless you have a really large user base it's
> > > muchthe
> > > > > > cheaper to buy SSDs or more effective to upgrade clients. For
> > 6kThat
> > > > > you'd
> > > > > > spend on one of the Fusion cards, you could get 15-20 SSD.
> > > shouldto
> > > > be
> > > > > > PLENTY of iops for just about anyone, more space, more
> redundancy,
> > > etc.
> > > > > > I see a lot of people that want to go straight to the server
> > > resolveyour
> > > > > > performance issues. More often than not the vast majority of
> > > > > > processing time is due to work on the client side, not the<mailto:r.morton03%40yahoo.com>
> server.
> > > Run
> > > > > > some
> > > > > > tests and check for yourself. Test some clients with the
> > performance
> > > > > tool.
> > > > > > Check the queue length on your server. If your queue is short,
> > > > > more/faster
> > > > > > disks isn't going to do much for you.
> > > > > > On Mon, May 14, 2012 at 9:41 AM, r.morton03 <
> r.morton03@... <mailto:r.morton03%40yahoo.com>
> > > <mailto: <mailto:%0b>Accelerator??
> > > > > > <mailto:r.morton03%40yahoo.com> > wrote:
> > > > > > > Has anybody seen/heard about the Fusion IO and HP
> > > They<mailto:vantage%40yahoogroups.com>
> > > > > > look
> > > > > > > interesting... I heard a testimony at Insights that it works
> > > insanely
> > > > > > fast
> > > > > > > and smooth..
> > > > > > > --- In vantage@yahoogroups.com
> vantage%40yahoogroups.comcan
> > > > > > <mailto:vantage%40yahoogroups.com> , John
> > > > > > Driggers <waffqle@...> wrote:
> > > > > > > > If you can afford SSD you want them. Period.
> > > > > > > > The enterprise drives are still expensive. That said, you
> > usethem
> > > > the
> > > > > > > > consumer drives so long as they are raided. Stick 4 of
> inwill
> > a
> > > > Raid
> > > > > > 10
> > > > > > > > and put a spare or two on the shelf. I know some people
> > > > disagreeneed
> > > > > > > > here. But for my money, if the performance is where you
> itmuch
> > > and
> > > > > > the
> > > > > > > > reliability is there, I see no reason to spend 4-5x as
> forsuccess
> > > > > > > enterprise
> > > > > > > > drives. Especially with SSD, the performance gulf between
> > > > > > > > consumer/enterprise drives isn't nearly as vast as it once
> was.
> > > > > > > > The reliability of SSDs overall has gotten much better in
> > recent
> > > > > > years. I
> > > > > > > > know a lot of people running them in workstations without
> > > > mirroring.
> > > > > > > > On Fri, May 11, 2012 at 10:51 AM, Anon <jgiese@...>wrote:
> > > > > > > > > Not client related but still performance related, what
> server
> > > > > > > > > configurations have you guys found most performance
> > in?performance
> > > > > > > > > I have a split install SQL and Epicor on two seperate
> > physical
> > > > > boxes
> > > > > > > and
> > > > > > > > > SQL DBs on a storage array connected to the SQL box.
> > > > > > > > > I have caught wind that there are some strong
> > > > increasesthat?
> > > > > > in
> > > > > > > not
> > > > > > > > > having a split install. What are peoples thoughts on
> > I'vealmost
> > > > > seen
> > > > > > a
> > > > > > > lot
> > > > > > > > > of back and fourth on SSD on the forum here, and I'm
> > > > > thinkingperformance,
> > > > > > > that
> > > > > > > > > it's uncontested that SSD are going to get you
> > butnot
> > > > > > without
> > > > > > > > > spending large cash on great drives the reliability is
> > > there?<mailto:vantage%40yahoogroups.com>
> > > > > Is
> > > > > > > that a
> > > > > > > > > fair summation of the discussions I have seen on here?
> > > > > > "Joshua Giese" <jgiese@> wrote:
> > > > > > > > > > Interesting. Why would the IO of the hard drive make
> such a
> > > > > > > difference.
> > > > > > > > > > Isn't most of Epicor just stored in RAM?
> > > > > > > > > > Joshua Giese
> > > > > > > > > > CTO
> > > > > > > > > > _____
> > > > vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com>
> > > > > > > Behalf
> > > > > > > > > > Of too_much_hg
> > > > > > > > > > Sent: Wednesday, May 09, 2012 4:48 PM
> > > vantage%40yahoogroups.com>7
> > > > > > > > > > Subject: [Vantage] Re: Client Computers
> > > > > > > > > > If you want to add some serious performance to your
> > desktops,
> > > > > > > replace the
> > > > > > > > > > hard drive with an SSD.
> > > > > > > > > > I put an SSD in my desktop and it made a noticable
> > > difference.
> > > > > > > > > > I am running an HP DC5750 (Dual Core 2.8 Ghz) Windows
> x64<mailto:vantage%40yahoogroups.com>
> > > > w/8GB
> > > > > > RAM
> > > > vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com<mailto:vantage%40yahoogroups.com%3cmailto:%0b> <mailto:
> > > > vantage%40yahoogroups.com%0b>testing
> > > > > > > > > "Anon"
> > > > > > > > > > <jgiese@> wrote:
> > > > > > > > > > > I am looking to purchase a client computer for
> toor
> > > see
> > > > > if
> > > > > > I
> > > > > > > want
> > > > > > > > > > to replace a larger population of computers. As far as
> > > desktops
> > > > > > for
> > > > > > > > > > clients go, what kind of specs are going to be most
> > > beneficial
> > > > to
> > > > > > a
> > > > > > > high
> > > > > > > > > > performing client computer. Aside from your standard
> > > > memory/proc
> > > > > > > > > > requirements what additional considerations should be
> made.
> > > At
> > > > > > base
> > > > > > > value
> > > > > > > > > > I'm starting with looking at anything with a i5 Proc
> > > higher<mailto:waffqle%40gmail.com>
> > > > > and
> > > > > > > 4GB
> > > > > > > > > ram
> > > > > > > > > > or higher.
> > > > > > > > *John Driggers*
> > > > > > > > *High End Dev, System Design, Profit Drinking*
> > > > > > > > **:: 904.404.9233*
> > > > > > > > *:: waffqle@...*
> > > > > > > > *:: NO FAXES*
> > > > > > *John Driggers*
> > > > > > **:: 904.404.9233*
> > > > > > *:: waffqle@... <mailto:waffqle%40gmail.com>
> > > > waffqle%40gmail.com>You
> > > > > > *:: NO FAXES*
> > must<http://groups.yahoo.com/group/vantage/files/>
> > > access.
> > Builder
> > > > and
> > > > http://groups.yahoo.com/group/vantage/files/>goto:
> > > > > > http://groups.yahoo.com/group/vantage/linksYahoo! Groups Links<http://groups.yahoo.com/group/vantage/files/>
> must
> > access.
> Builder
> > > and
> > > > http://groups.yahoo.com/group/vantage/files/><mailto:waffqle%40gmail.com>
> > > > *John Driggers*
> > > > **:: 904.404.9233*
> > > > *:: NO FAXES*
> > 05/15/12
> > > *John Driggers*
> > > **:: 904.404.9233*
> >must
> > > *:: NO FAXES*
> > > have already linked your email address to a yahoo id to enableaccess.
> )Builder
> and<http://groups.yahoo.com/group/vantage/files/>
> > > (2) To search through old msg's goto:<mailto:waffqle%40gmail.com> *
> *John Driggers*
> **:: 904.404.9233*
> *:: NO FAXES*and
> Crystal Reports and other 'goodies', please goto:<http://groups.yahoo.com/group/vantage/files/>
> (2) To search through old msg's goto:[Non-text portions of this message have been removed]
