Epicor 'Personal' contacts
Has anyone run into an issue with Customer contacts defaulting to ‘Personal’ contacts. I have a user that can’t see his Customer’s contacts. I had this issue once before where there was a filter that was not showing and clearing all filters fixed it. This is different. There are no filters and ‘Retrieve Contacts’ is checked. There is a search icon (magnifying glass) showing on his Contacts panel next to the filter icon (funnel) that I have not seen on anyone else. If we click on the search, it is defaulting to ‘Personal’. If we change it to ‘Basic’, his contacts show up.
I don’t know where the search icon came from. The user has no personalizations showing under ‘Personalization Purge’.
Thanks, Zane
Are you running Classic UI or Kinetic? “Personalization Purge” is classic only.
He is using Kinetic.
Could it be a saved “Quick Search” as default?
DaveO
Possible, but I don’t even know how to create a quick search on the Contact Panel. I can go to Customer Contact Search, but it doesn’t offer a ‘Personal’ option under the type drop-down.
If you’re on 25.2.x then the personalizations are in App Studio. If not then there is a user creates dashboard or a datafix from Epicor.
