And at one point the engineering workbench did not function properly....but they could have fixed that by now.
M. Manasa Reddy
manasa@...<mailto:manasa@...>
630.806.2000 x1515
Ex scientia, vera
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Mark Wagner
Sent: Wednesday, May 02, 2012 3:55 PM
Subject: Re: [Vantage] Epicor SAAS (Express) vs. Vantage 8/Epicor 9
The express product (or Saas) is the same product, so if you have experience with Vantage administering the express product for Epicor 9 will be similar. The big difference in the SaaS model is you will not have certain features, so for instance, if your company uses the product configurator you will not be abe to use the express product as it does not support the configurator
From: Tony Hughes <thughes281@...<mailto:thughes281%40yahoo.com>>
Sent: Wednesday, May 2, 2012 3:17 PM
Subject: [Vantage] Epicor SAAS (Express) vs. Vantage 8/Epicor 9
How different are the products?
Are the same basic concepts behind Vantage 8 or Epicor 9 in the Express product?
I am asking to see if a person with experience administering the Express product will have a good start with moving to the 8 or 9 product.
Thanks for your advice.
Total Control Panel
Login<https://asp.reflexion.net/login?domain=weldcoa.com>
To: manasa@...<https://asp.reflexion.net/address-properties?aID=516126014&domain=weldcoa.com>
From: sentto-20369-109855-1335992074-manasa=weldcoa.com@...<https://asp.reflexion.net/address-properties?aID=654290108&domain=weldcoa.com>
Message Score: 30
High (60): Pass
My Spam Blocking Level: Low
Medium (75): Pass
Low (90): Pass
Block<https://asp.reflexion.net/FooterAction?ver=2&bl-sender-address=1&rID=516126014&aID=654290108&domain=weldcoa.com> this sender
Block<https://asp.reflexion.net/FooterAction?ver=2&bl-sender-domain=1&rID=516126014&aID=654290108&domain=weldcoa.com> returns.groups.yahoo.com
This message was delivered because the content filter score did not exceed your filter level.
M. Manasa Reddy
630.806.2000 x1515
Ex scientia, vera
Total Control Panel
Message Score: 30
High (60): Pass
Medium (75): Pass
Low (90): Pass
