We are trying to use the weight verification on outgoing parts. We need to connect a USB scale to the workstation running Epicor and then have it read actual weight from external scale and input the weight data into the program.
Any help from any others who have pulled this off?
There should be a thread/wiki on here of how to connect from SaaS to on premise devices and get info from them. I feel like it’s scattered. There’s definitely threads on doing this… maybe not a scale, but
Unless it’s changed the workstation only works with serial scales. Each scale is specific so you’ll need the serial info from the manufacture. But once you get it connected it works without much issue. We’ve used scales through Epicor workstations for 6-7 years.
Not being a smartaleck but how’s Kinetic going to know where that workstation-associated USB scale is actually connected? Only available for on-prem?
Yeah that’s what I thought too Kevin, I just couldn’t say because I don’t have a scale enabled there and have never used scale functionality in cloud.
