Having it on usually lends a solid performance boost, but you want to
disable it for now to see if it's causing your issue.
*John Driggers*
*Chief Data Wrangler*
*I have an Epicor blog <http://usdoingstuff.com/>. How useful is that?*
*:: 904.404.9233
:: waffqle@...
:: http://www.usdoingstuff.com <http://www.usdoingstuff.com/>
*John Driggers*
*:: 904.404.9233
:: waffqle@...
On Thu, Aug 16, 2012 at 3:28 AM, Chris Thompson <chriselectrix@...>wrote:
> Should memory cache be ticked or unticked?
> From: Greg Payne <gpayne@...>
> To: "vantage@yahoogroups.com" <vantage@yahoogroups.com>
> Sent: Wednesday, 8 August 2012, 17:19
> Subject: RE: [Vantage] Re: Epicor - Windows 7
> I was advised to also delete the c:\ ProgramData\Epicor directory ( with
> Epicor closed ) as clear memory cache only clears some info.
> Have you tried in XP mode? I have to run DMT on one 64bit machine in
> compatibility mode, but another is fine.
> Greg Payne
> Of cubcrafters_it
> Sent: Wednesday, August 08, 2012 11:50 AM
> To: vantage@yahoogroups.com
> Subject: [Vantage] Re: Epicor - Windows 7
> Memory Cache is under Tools -> Options -> Memory Cache. Check that setting
> on the particular screen in question.
> --- In vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>, Chris
> Thompson <chriselectrix@...<mailto:chriselectrix@...>> wrote:
> > We are on 9.04.505c and it happens usually Engineering Workbench, Part
> Maintenance and Warehouse Bin.
> > We have tried clearing the Epicor cache, but it still occurs.
> > Epicor suggested it might be memory cache but I have no idea how to sort
> this?
> > From: Miguel Santillan <msantillan@...<mailto:msantillan@...>>
> > To: "vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>" <
> vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>>
> > Sent: Tuesday, 7 August 2012, 16:27
> > Oddly enough this just started happening to a user of mine.
> > Installed Win7 64 bit for this new user and she is having issues with
> saving to the Supplier Price List when she clicks on Primary Supplier.
> > 9.05.607A
> > When does this happen for your user?
> > Miguel A. Santillan
> > Compass Components, Inc.
> > From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> [mailto:
> vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>] On Behalf Of
> Chris Thompson
> > Sent: Tuesday, August 07, 2012 12:43 AM
> > To: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>
> > Has anyone else experienced this?
> > From: Chris Thompson <chriselectrix@...<mailto:chriselectrix%40ymail.com
> <mailto:chriselectrix@...%3cmailto:chriselectrix%40ymail.com>>>
> > To: "vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:
> vantage%40yahoogroups.com>" <vantage@yahoogroups.com<mailto:
> vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com>>
> > Sent: Wednesday, 18 July 2012, 14:34
> > Subject: Epicor - Windows 7
> > Hi All
> > We are having an issue where a user is making changes on Epicor and
> saving, but when they go back in to check, the changes are not saving.
> > This has happened a number of times with the same user.
> > This problem never happened until the user switched to a Windows 7
> machine.
> > Has anybody has a similar issue?
> > If so do you have a fix?
> > Thanks,
> CONFIDENTIALITY NOTICE
> The information contained in this communication, including attachments, is
> privileged and confidential. It is intended only for the exclusive use of
> the addressee. If the reader of this message is not the intended recipient,
> or the employee or agent responsible for delivering it to the intended
> recipient, you are hereby notified that any dissemination, distribution or
> copying of this communication is strictly prohibited. If you have received
> this communication in error, please notify us at (727) 578-6258 and
> immediately delete the communication.
> "This (document/presentation) may contain technical data as defined in the
> International Traffic In Arms Regulations (ITAR) 22 CFR 120.10. Export of
> this material is restricted by the Arms Export Control Act (22 U.S.C. 2751
> et seq.) and may not be exported to foreign persons without prior approval
> form the U.S. Department of State."
