I believe the trial license only works with the "Demonstration Database" not
your actual DB.
The license uses an algorithm that uses the expiration date and your company
ID as the keys to generate the license.
If the company ID doesn't match the one in the license, then it won't work.
epdba1337
Sent: Monday, May 20, 2013 9:28 AM
Subject: [Vantage] Re: Epicor9.05.702 Moving to direct from Vantage 6
So I got the trial license but it checks the server side license too and
fails me. Tried importing with admin console with no success and the license
is sitting in my client directory.
your actual DB.
epdba1337
--- In vantage@yahoogroups.com, Gary Parfrey <garyp@...> wrote:
> Full documentation, dmtdiff tool and demo license are on epicweb
> support site It is in the Epicor DMT menu node above where you would
> normally download the software
> Gary
> Behalf Of epdba1337
> Sent: 17 May 2013 15:24
> I have the program, where is this demo license... Can I has?
> -Josh
> --- In vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>, Greg
Payne <gpayne@<mailto:gpayne@>> wrote:
> > Having just gone thru migration from a previous system, I would second
the use of DMT. There are other data tables or defaults that are populated
by the BO and that could cause a lot of issues if you just hit the tables.
There is also the Patchfld table which holds data that will appear in
datasets elsewhere.
> > Plus DMT is easy to use if you already have the ODBC setup from the
previous system.
> > If you don't have it in your install files, then you can get it from
epicweb and a demo license to try it out is available.
> > Greg
> > From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>
> > [mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>]
> > On Behalf Of Jose Gomez
> > Sent: Friday, May 17, 2013 10:05 AM
> > To: Vantage
> > Subject: Re: [Vantage] Epicor9.05.702 Moving to direct from Vantage
> > 6
> > I would highly recommend you get DMT and use it to import the data
> > into 9 it goes through the business logic and validates and makes
> > sure your data isn't going to be causing any problems
> > *Jose C Gomez*
> > *Software Engineer*
> > *T: 904.469.1524 mobile
> > E: jose@
> > http://www.josecgomez.com
> > <http://www.linkedin.com/in/josecgomez>
> > <http://www.facebook.com/josegomez>
> > <http://www.google.com/profiles/jose.gomez>
> > <http://www.twitter.com/joc85>
> > <http://www.josecgomez.com/professional-resume/>
> > <http://www.josecgomez.com/feed/>
> > <http://www.usdoingstuff.com>
> > *Quis custodiet ipsos custodes?*
> > On Fri, May 17, 2013 at 10:03 AM, epdba1337
<epdba1337@<mailto:epdba1337@>> wrote:
> > > Greetings,
> > > As this is my first post I will begin by prefacing that I am
> > > teaching my self everything about this ERP solution and are
> > > looking for any tips and tricks that may help me on my journey. I
> > > was hired 4 months ago, introduced to the Vantage 6 environment and
have been building a knowledge base since.
> > > Upon discovering that I could install and configure the Epicor 9
> > > software I decided to spearhead an upgrade from V6 to the most
> > > current version. I have spent the last few months reading
> > > documentation for E9 and have more than a few questions on best
practices and training strategies.
> > > For the purposes of this post I will ask if it is possible to use
> > > ODBC to transfer data direct from V6 to E9.
> > > Note: I have installed the 64bit version of E9 and V6 is 32 bit based.
> > > Note2: I plan on using a third party program to store the data in
> > > an intermediate step if necessary. (Access or SQL Server)
> > > Note3: I realize that there are massive schema differences between
> > > the two versions but if the information is stored in an
> > > intermediate container then I can define temp tables and
> > > programmatically slice&Dice the data to conform to the new schema
correct?
> > > Note4: I have already succeeded in transferring data out of V6
> > > into MSAccess and will be setting up ODBC to the new E9 Server
> > > today. Ill post my findings after I attempt a basic transfer.
> > > Thanks!
> > > -Josh
> > Useful links for the Yahoo!Groups Vantage Board are: ( Note: You
> > must have already linked your email address to a yahoo id to enable
> > access. )
> > (1) To access the Files Section of our Yahoo!Group for Report
> > Builder and Crystal Reports and other 'goodies', please goto:
> > http://groups.yahoo.com/group/vantage/files/.<http://groups.yahoo.co
> > m/group/vantage/files/>
> > http://groups.yahoo.com/group/vantage/messages
> > (3) To view links to Vendors that provide Vantage services goto:
> > http://groups.yahoo.com/group/vantage/linksYahoo! Groups Links
> > CONFIDENTIALITY NOTICE
> > The information contained in this communication, including attachments,
is privileged and confidential. It is intended only for the exclusive use of
the addressee. If the reader of this message is not the intended recipient,
or the employee or agent responsible for delivering it to the intended
recipient, you are hereby notified that any dissemination, distribution or
copying of this communication is strictly prohibited. If you have received
this communication in error, please notify us at 727-578-6280 and
immediately delete the communication.
> > "This (document/presentation) may contain technical data as defined in
the International Traffic In Arms Regulations (ITAR) 22 CFR 120.10. Export
of this material is restricted by the Arms Export Control Act (22 U.S.C.
2751 et seq.) and may not be exported to foreign persons without prior
approval form the U.S. Department of State."
