Epicor's DMT Blank Title 92378
Not that I know of, but I haven't seen the bill yet either (grin) Will be contacting my CAM
--- In vantage@yahoogroups.com, Mark Wonsil <mark_wonsil@...> wrote:
> Stan wrote:
> > Depends upon how many users you're licensed for. Also it increases your
> > yearly support contract by 20% of original cost.
> Buying DMI raises your support contract???
Recently Epicor has introduced a new utility Called Data Management Tool (DMT). I am considering the possibility of using that to upgrade my db to 9.0. Does any one have experience with this tool?
I am currently at 6.1 and know that this tool can only be used at 8.03 or higher. So it would require converting the db from 6.1 to 8.03 in the conventional method, then using the tool to "selectively" export/import records into 9.x.
Any input or advice concerning the tool or the upgrade method described would be greatly appreciated.
Stan Chmura
IT Manager
Fiberoptics Technology, Inc.
To the best of my knowledge, DMT does not Export data - you would have to use BAQs for that. DMT does not Work with all tables I'm not sure what you would do for the excluded tables (my experience is limited to 8.03.405)
It is an excellent tool for performing mass updates to records such as supplier group as someone posted yesterday....
It can import data into new db as well, but there are setups that still need to be done using the Vantage/Epicor apps.
Your CAM should be able to supply you with documents to review
> Thanks
> Stan Chmura
> IT Manager
Hi
We have used this tool for quite a while and found it to be excellent, we are are on 8.03.405a and have recently used it to import new BOM and BOO structures as well as part revisions etc. We have also found it to be very quick at importing the data. It doesnt do all the tables in Vantage but it covers most of the major tables. Most of all it is very easy to use, I highly recommend it.
Mark L
Teagle Machinery Ltd
> > Thanks
> > Stan Chmura
> > IT Manager
What are you importing from? Another version of Vantage or Vista?
_____
Mark
Sent: Wednesday, August 04, 2010 9:55 AM
Subject: [Vantage] Re: Epicor's DMT
Hi
Mark L
records into 9.x.
> > Thanks
> > Stan Chmura
> > IT Manager
Originally we exported the data from our old non Epicor ERP system into excel spreadsheets in the format vantage likes then used this tool to import into Vantage. Now we just create the data in excel that we need and import into Vantage. We have also used this to make changes to the data on mass, you still need to export it out of Vantage / Vista first.
> _____
> Mark
> Hi
> Mark L
> records into 9.x.
> > > Thanks
> > > Stan Chmura
> > > IT Manager
how much does this tool cost?
Ephraim Feldman
Sender: vantage@yahoogroups.com
Date: Wed, 04 Aug 2010 13:55:01
To: <vantage@yahoogroups.com>
Reply-To: vantage@yahoogroups.com
Hi
Mark L
> > Thanks
> > Stan Chmura
> > IT Manager
Here's a data sheet I got from my CAM
_____
effgroups@...
Sent: Wednesday, August 04, 2010 12:41 PM
Subject: Re: [Vantage] Re: Epicor's DMT
Ephraim Feldman
From: "Mark" <teaglem@... <mailto:teaglem%40yahoo.co.uk> >
Sender: vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com>
To: <vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> >
Reply-To: vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com>
Hi
Mark L
records into 9.x.
> > Thanks
> > Stan Chmura
> > IT Manager
Can you sent the sheet off the forum? Its not getting posted.
Ephraim Feldman
Date: Wed, 4 Aug 2010 15:15:41
Subject: RE: [Vantage] Re: Epicor's DMT
_____
effgroups@...
Ephraim Feldman
Hi
Mark L
records into 9.x.
> > Thanks
> > Stan Chmura
> > IT Manager
I'm not the one since I haven't gotten myself trained up on DMT, but if anyone needs a good lead for some help with this tool I've got a good source.
> _____
> effgroups@...
> Ephraim Feldman
> Hi
> Mark L
> records into 9.x.
> > > Thanks
> > > Stan Chmura
> > > IT Manager
