Epicor's tech support says
That may be true if you are using the list lookup code
the OpMaster List dataset does not include the Comment Text field.
If you call the adapter using the BO and the GetRows method then you
get the entire dataset returned to you which includes three tables
and all the fields.
--- In vantage@yahoogroups.com, "sanfranc415" <sanfranc415@...> wrote:
> I talked with Epicor tech support yesterday and they said
> the "OpMasterAdapter" was created to include only fields that the
> developers thought you'd need to access to, so they didn't include
> the "commenttext" field. Ok, they said I could create my own
> UD01Adapter, but I'd need to use SDK.
> So, I don't have access to view or change what is being accessed my
the
> OpMasterAdapter?
> Thanks,
> --SF
So, I don't have access to view or change what is being accessed my the
OpMasterAdapter?
--SF
