I am working on a configurator and I want to group controls together. When I place controls on to the group box they don’t take on the background color of the groupbox. How can I make the controls children of the rectangle / EpiGroupBox or share its background color?
I was trying to use the tutorial by @josecgomez (Jose C Gomez) but that only changed the background color of the list part of the combo and not the label part.
Hmm, actually this seems to be screwing up the data binding or something, when ever I select a value for the combo box now I get the following error:
Error Detail
Message: Object reference not set to an instance of an object.
Program: Erp.Lib.Configurator.dll
Method: RefreshTextInControls
Client Stack Trace
at Erp.Lib.Configurator.Runtime.InputFieldPropertiesLib.RefreshTextInControls(InputCollection InputControls, String ColumnName, String value)
at Erp.UI.Cfg.TESTfd47df31e6c34e94901b081e02af8543.Controllers._Pianowire_ConfiguratorController._Pianowire_ConfiguratorPage1_ColumnChanged(Object sender, DataColumnChangeEventArgs e) in c:\Users\epurdy\AppData\Local\Temp\ConfigDump\Client_Pianowire_ConfiguratorController.cs:line 3213
at System.Data.DataColumnChangeEventHandler.Invoke(Object sender, DataColumnChangeEventArgs e)
at System.Data.DataTable.OnColumnChanged(DataColumnChangeEventArgs e)
at Erp.BO.Cfg.TESTfd47df31e6c34e94901b081e02af8543._Pianowire_ConfiguratorDataSet._Pianowire_ConfiguratorPage1DataTable.OnColumnChanged(DataColumnChangeEventArgs e) in c:\Users\epurdy\AppData\Local\Temp\ConfigDump\Client_Pianowire_ConfiguratorDataSet.cs:line 2359
at System.Data.DataRow.set_Item(DataColumn column, Object value)
at System.Data.DataRowView.SetColumnValue(DataColumn column, Object value)
at System.Data.DataRowView.set_Item(String property, Object value)
at Ice.Lib.Framework.EpiUltraCombo.updateDataSource(Object sender, Boolean forceUpdate)
