Ok, my memory wasn't as good as I hoped.
I just ran a test.
private static void epiButtonC1_Click(object sender, System.EventArgs args)
epiUltraComboC1.Text = String.Empty;
The above works for me. So that's the property you want. There may be an
issue with firing it on 'ValueChanged' since it updates the text itself. Try
grabbing a different event or just attaching your code to a button to
verify.
I just ran a test.
verify.
On Mon, Dec 20, 2010 at 1:46 PM, Aaron <aaronmclements@...> wrote:
> Thanks for the suggestion. I just tried that and it doesn't clear the C1
> box.
> --- In vantage@yahoogroups.com <vantage%40yahoogroups.com>, Waffqle
> Driggers <waffqle@...> wrote:
> > I believe 'selectedtext' is the property you want to clear.
> > On Mon, Dec 20, 2010 at 11:43 AM, Aaron <aaronmclements@...> wrote:
> > > Epicor 9.04.506a
> > > I have the following two events:
> > > Private Sub epiUltraComboC2_ValueChanged(ByVal sender As Object, ByVal
> args
> > > As System.EventArgs)
> > > ' ** Place Event Handling Code Here **
> > > epiUltraComboC1.Value = DBNull.value
> > > EpiMessageBox.Show("T "&epiUltraComboC1.Text)
> > > EpiMessageBox.Show("V "&epiUltraComboC1.Value)
> > > End Sub
> > > Private Sub epiUltraComboC1_BeforeDropDown(ByVal sender As Object,
> ByVal
> > > args As System.ComponentModel.CancelEventArgs)
> > > SearchOnEmpBasicAdapterFillDropDownC1()
> > > End Sub
> > > I'm trying to clear the value and text of C1 anytime the value of C2
> > > changes. The problem is the data is not clearing. I've tried assigning
> > > String.Empty as well. The first two message boxes popup "blank", as
> > > expected, when I change the value of C2. However the edit box of C1
> still
> > > contains the data (as viewed on the GUI). It doesn't get cleared.
> > > Furthermore, when I click the dropdown on C1, it's text and value data
> still
> > > has the original values.
> > > Long winded explanation for a short question. How do I clear the edit
> box
> > > of an epiUltraCombo?
