EpiUltraComboPlus dropdown change selected row
I have a customization that is working from the Case Entry screen. Basically the code performance a replication of the current CaseNum in view.
Once the replication is completed, I call a GetByID with the new CaseNum to refresh the screen. This also works. Initial case open is 51552 and the replicated case is 51561
However, the CaseList drop down remains focused on the original case number 51552. This a drop down field which does contain the replicated case number 51561.
Can someone suggest how to force/change the row focus to the replicated case number 51561, see snapshots below:
Mazin
I used this post for my solution. Thanks Jose.
How to set in code the EpidataView record being CurrentDataRow - ERP 10 - Epicor User Help Forum (epiusers.help)
Just set the Row property of the data view
myDataView.Row=10;
