Why not just run it pre-processing on GetByID ? Then you can avoid the FKV
and screen customization all together.
On Tue, Apr 12, 2011 at 1:52 PM, pambro6225 <pam.broviak@...>wrote:
> Looking for assistance with a Purchase Order Entry customization. I've
> tried BPMs in pre and post process directives, as well as other events as
> suggested in other forum responses, but I'm not able to succeed.
> I added a new Inspection Required checkbox (Part.CheckBox05) at the Part
> Maintenance level, and added a PO Update Pre Process BPM that works
> perfectly to check the Inspection Required checkbox
> (PODetail.RcvInspectionReq) on the PO Entry Line screen whenever the same
> part Part Maintenance Inspection Required checkbox is checked.
> This works great for new and changed POs added manually via the Purchase
> Order Entry screen, but doesn't work when new POs are created via the
> Generate POs from Suggestions process.
> I added a Part foreign key view linked by PartNum to parent view PODetail,
> and added field Part.CheckBox05 to the Part FKV. I then added an extra
> checkbox to the PO Entry Line screen using FKV Part.CheckBox05 as the
> datasource. The new checkbox is checked on the screen when it's supposed to
> be, but it doesn't trigger the Inspection Required checkbox to be checked
> when FKV Part.CheckBox05 = True, which is my goal.
> If someone familiar with this has time could they please take a look at my
> Form Event EpiViewNotification code below and see what changes I would need
> to make to get this to work correctly?
> Thanks in advance - Pam
> '// Custom VB.NET code for POEntryForm
> '// Created: 9/6/2007 2:07:40 PM
> Imports System
> Imports System.Data
> Imports System.Diagnostics
> Imports System.Windows.Forms
> Imports System.ComponentModel
> Imports Microsoft.VisualBasic
> Imports Epicor.Mfg.UI
> Imports Epicor.Mfg.UI.FrameWork
> Imports Epicor.Mfg.UI.ExtendedProps
> Imports Epicor.Mfg.UI.FormFunctions
> Imports Epicor.Mfg.UI.Customization
> Imports Epicor.Mfg.UI.Adapters
> Imports Epicor.Mfg.UI.Searches
> Imports Epicor.Mfg.BO
> Module Script
> '// ** Wizard Insert Location - Do Not Remove 'Begin/End Wizard Added
> Module Level Variables' Comments! **
> '// Begin Wizard Added Module Level Variables **
> Private WithEvents edvPODetail As EpiDataView
> Private WithEvents edvPart As EpiDataView
> Private WithEvents chkEpiCustom1 As EpiCheckBox
> Private WithEvents chkInspectionRequired As EpiCheckBox
> '// End Wizard Added Module Level Variables **
> '// Add Custom Module Level Variables Here **
> Sub InitializeCustomCode()
> '// ** Wizard Insert Location - Do not delete 'Begin/End Wizard Added
> Variable Intialization' lines **
> '// Begin Wizard Added Variable Intialization
> edvPODetail = CType(oTrans.EpiDataViews("PODetail"), EpiDataView)
> edvPart = CType(oTrans.EpiDataViews("Part"), EpiDataView)
> '// End Wizard Added Variable Intialization
> '// Begin Custom Method Calls
> '// End Custom Method Calls
> End Sub
> Sub DestroyCustomCode()
> Object Disposal' lines **
> '// Begin Wizard Added Object Disposal
> '// edvPODetail = Nothing
> '// End Wizard Added Object Disposal
> '// Begin Custom Code Disposal
> '// End Custom Code Disposal
> End Sub
> Private Sub edvPODetail_EpiViewNotification(view As EpiDataView, args As
> EpiNotifyArgs) Handles edvPODetail.EpiViewNotification
> '// ** Argument Properties and Uses **
> '// view.dataView(args.Row)("[FieldName]")
> '// args.Row, args.Column, args.Sender, args.NotifyType
> '// NotifyType.Initialize, NotifyType.AddRow, NotifyType.DeleteRow,
> NotifyType.InitLastView, NotifyType.InitAndResetTreeNodes
> '// edvPart = CType(oTrans.EpiDataViews("Part"), EpiDataView)
> '// edvPODetail = CType(oTrans.EpiDataViews("PODetail"), EpiDataView)
> chkEpiCustom1 =
> CType(csm.GetNativeControlReference("49968fd7-658e-444a-b8a4-a10e30ca1bf0"),EpiCheckBox)
> chkInspectionReq =
> CType(csm.GetNativeControlReference("6c0686e9-1d15-48d3-83dd-dbe108176af8"),EpiCheckBox)
> If (args.NotifyType = EpiTransaction.NotifyType.AddRow) and
> edvPart.dataview(edvPart.Row)("CheckBox05") = True Then
> '// edvPODetail.dataview(edvPODetail.Row)("RcvInspectionReq") =
> edvPODetail.dataview(edvPODetail.Row)("RcvInspectionReq").Checked = True
> End If
> End Sub
> End Module
