When I restart the Process server it says “STARTING”. Do I have to wait for it to be running before I start the task agent?
@randallweber Here is my batch stop start I used in E9. I separated the printing to its own appserver so I could stop and start it alone without users knowing.
@echo off
echo Starting 905 Database and AppServers...
set DLC=E:\Epicor\OE102A
set PATH=%DLC%\BIN;%PATH%
set LIB=%DLC%\LIB;%LIB% cd \Epicor905\db
echo .
echo .
echo STOPPING LOCAL DB/APPSERVERS...
cd \Epicor905\db
call asbman -name EpicorTest905ProcessServer -stop
call asbman -name EpicorTest905TaskAgent -stop
call asbman -name EpicorTest905Print -stop
call asbman -name EpicorTest905 -stop
call dbman -host localhost -port 20931 -database EpicorTest905 -stop
del "E:\Epicor905\Server\Logs\EpicorTest905*.Log"
del "E:\EpicorData\*.*" /Q
del "E:\EpicorTemp\*.*" /Q
Ping 127.0.0.1 -n 30 > nul
echo .
echo .
echo STARTING LOCAL DB/APPSERVERS...
call dbman -host localhost -port 20931 -database EpicorTest905 -start
call asbman -name EpicorTest905 -start
call asbman -name EpicorTest905Print -start
call asbman -name EpicorTest905TaskAgent -start
call asbman -name EpicorTest905ProcessServer -start
echo All Appservers started
Thanks. Will the batch file wait for one command to finish before the next? If not, it seems I should be able to start the task agent when the process server is still starting.
I assumed it did but it has been a while. I had to add the 30 pings to be sure it was fully down before restarting.
As per my experience,
Stop Process Server first, then stop Task Agent.
After that, start Task Agent and wait until it is “Active”, then start Process Server.
