Trying my luck retrieving data from a baq in Application Studio
how do I set the erp-baq BAQ Execute Options to reference a parameter I have set in the BAQ
I have tried myParameter = ‘{view.field}’ for the Where which results in error, I have tried @myParameter = ‘{view.field}’ for the Where which also results in a different error. The Application Studio online Help is most unhelpful with this…
To use a BAQ with parameter inputs, please use the rest-erp event action (Ice.BO.DynamicQuerySvc::ExecuteByID) with the correct setup on the Method Parameters for the executionParams field… something like below sample…
"ExecutionParameter": [
"ParameterID": "PartNum",
"ParameterValue": "{KeyFields.PartNum}",
"ValueType": "string"
"ParameterID": "CompanyCode",
"ParameterValue": "{CallContextBpmData.Character01}",
Hope that helps.
That worked - Thanks
How did you structure your response parameters @Ishkaran when using dynamic query? When I have mine setup like this I get the toLowerCase error in the dev tools console with the rest-erp call.
I recreated the event and seems to have resolved the error in the rest call
