I have this error using DeleteByID of Customer BO in Visual Studio.
Has someone solved the problems deleting records using proxy implementation?
Object reference not set to an instance of an object.
at Erp.Services.BO.CustomerSvc.CustomerBeforeDelete() in C:_Releases\ERP\UD10.1.600.9\Source\Server\Services\BO\Customer\Customer.cs:line 3947
at Ice.Services.Trace.TablesetProfilingCollector.DoRowEventTrace(String tableName, String methodName, Int32 rowCount, Action action) in C:_Releases\ICE\3.1.600.9\Source\Framework\Epicor.Ice\Services\TablesetProfilingCollector.cs:line 144
at Ice.TablesetBound3.DeleteRow(IceDataContext dataContext, String tableName, LinqRow dbRow, TablesetProfilingCollector parentTraceCollector) in C:\_Releases\ICE\3.1.600.9\Source\Framework\Epicor.Ice\Services\TablesetBound.cs:line 1307 at Ice.TablesetBound
3.OnDeleteByID(String logicalTableName, LinqRow dbRow) in C:_Releases\ICE\3.1.600.9\Source\Framework\Epicor.Ice\Services\TablesetBound.cs:line 817
at Erp.Services.BO.CustomerSvcFacade.DeleteByID(Int32 custNum) in C:_Releases\ERP\UD10.1.600.9\Source\Server\Services\BO\Customer\CustomerSvcFacade.cs:line 2209
at SyncInvokeDeleteByID(Object , Object[] , Object[] )
at System.ServiceModel.Dispatcher.SyncMethodInvoker.Invoke(Object instance, Object[] inputs, Object[]& outputs)
at Epicor.Hosting.OperationBoundInvoker.InnerInvoke(Object instance, Func2 func) at Epicor.Hosting.OperationBoundInvoker.Invoke(Object instance, Func
2 func)
at Epicor.Hosting.Wcf.EpiOperationInvoker.Invoke(Object instance, Object[] inputs, Object[]& outputs)
at System.ServiceModel.Dispatcher.DispatchOperationRuntime.InvokeBegin(MessageRpc& rpc)
at System.ServiceModel.Dispatcher.ImmutableDispatchRuntime.ProcessMessage5(MessageRpc& rpc)
at System.ServiceModel.Dispatcher.ImmutableDispatchRuntime.ProcessMessage11(MessageRpc& rpc)
at System.ServiceModel.Dispatcher.MessageRpc.Process(Boolean isOperationContextSet)
at Epicor.ServiceModel.Channels.ImplBase`1.ShouldRethrowNonRetryableException(Exception ex, DataSet[] dataSets)
at Erp.Proxy.BO.CustomerImpl.DeleteByID(Int32 custNum)
at ConsoleApplication3.Program.deletecustomer() in c:\Users\Jaicker\Documents\Visual Studio 2012\Projects\ConsoleApplication3\ConsoleApplication3\Program.cs:line 200
