Error-22 Blank Title 63943
thank you,
I will try all.
--- In vantage@yahoogroups.com, "bpbuechler" <pbuechler@...> wrote:
> Here is what Epicor's Answerbooks shows. In the future, if you
have
> Epicor Mtce/Support, you should be able to use EPICWEB-SEARCH
> ANSWERBOOKS function. I just typed in error=22 reading and this is
> what came up:
> Page 8677MPS
> PROBLEM: User is getting "Error=22 reading promsgs file" when
trying
> to login to Vista or Vantage.
> OR
> User gets a window that says "Unable to open message file PROMSGS."
> Looking at the Mfgsys.Lg, the log file is full of repeating
> "SRV 21: errno=9 reading promsgs file, it may have been deleted."
> "SRV 21: Previous message sent on behalf of user 219. (5512)"
> XA800
> XA803
> RESOLUTION:
> 1) Verify the setting of their environment variables. Specifically,
> DLC= in the mfgsys.ini must point to the mapped Open Edge folder.
> (i.e. DLC=D:\epicor\oe101b, the physical path on the server.)
Making
> sure user is not using a separate mfgsys.ini file found on
> workstation.
> 2) If a new Vantage client has been installed recently, check the
> Properties of the icon. Make certain the location specified for the
> mfgsys.ini file is valid.
> 3) Another problem that could cause this error is a permission
> problem with the Progress folder. Perhaps user has no access to the
> Progress folder. Verify user or user is a part of a group that has
> permissions to the Progress folder.
> 4) If the PROMSGS file exists, try setting it to read-only.
> Especially on Terminal Server and Citrix Metaframe, we have
> encountered problems with the operating system releasing PROMSGS
once
> it opens it. By setting permissions to read-only, the operating
> system can read the file, but will not take control of it.
> 5) Check the amount of free diskspace on the Vantage server. If the
> boot drive for the server or the drive the database is on are out
of
> space, there could be an error accessing PROMSGS.
> 6) Check the permissions on the share from the Vantage server.
> Especially on Windows 2003, resharing after a patch installation
does
> not necessarily have the same permissions.
> --- In vantage@yahoogroups.com, "sharma_nalini" <sharma_nalini@>
> wrote:
> > HI
> > I am still waiting for some advice .
> > what is the cause for getting this message and how can swe fix
this?
> > error=22 reading progmsgs file, it may have been deleted.
> > thank you
> > wrote:
> > > hi all,
> > > i just don't remember,
> > > how can i fix this problem below
> > > Please help me.
hi all,
Please help me.
HI
what is the cause for getting this message and how can swe fix this?
thank you
--- In vantage@yahoogroups.com, "sharma_nalini" <sharma_nalini@...>
wrote:
> hi all,
> Please help me.
Here is what Epicor's Answerbooks shows. In the future, if you have
what came up:
Page 8677MPS
PROBLEM: User is getting "Error=22 reading promsgs file" when trying
OR
Looking at the Mfgsys.Lg, the log file is full of repeating messages:
XA800
XA803
RESOLUTION:
(i.e. DLC=D:\epicor\oe101b, the physical path on the server.) Making
workstation.
encountered problems with the operating system releasing PROMSGS once
boot drive for the server or the drive the database is on are out of
Especially on Windows 2003, resharing after a patch installation does
wrote:
> HI
> thank you
> wrote:
> > hi all,
> > Please help me.
