Error 500 Blank Title 53490
Eunice,
If I am not mistaken this is either an ODBC error, or a Memory error.
Do you have ODBC set up on your A/P checks? If so, do you have it set up on
the terminal server and enabled in the shortcut file they use from the
terminal server?
I hope this might be of help, though I am not real sure, I am just working
from memory.
Good luck,
Aaron Hoyt
Vantage Plastics
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com]On Behalf Of
Eunice Corral
Sent: Friday, December 01, 2006 2:22 PM
Subject: [Vantage] RE: Error 500
Talking about errors... after one year of printing A/P
checks remotely thru Citrix, all of the sudden there comes
this Error 500. I modified the file again, set the
location, verify the database and put a fresh new copy and can
not get rid of the error.
This happens only thru Citrix. I created the icon to print from the
Citrix Server locally, and same error,
When I print locally from my workstation it prints fine, NO error!!
Anyone there that is familiar with these errors? Windows 2003, Citrix
Metaframe Presentation 3.0
I'll appreciate it.
Eunice Corral
Dudek & Bock Spring Mfg. Co.
Chicago, IL
I'll appreciate it.
Eunice Corral
Chicago, IL
