Error creating a tableset
This is my first attempt at trying to call a BO from code in a BPM. After hunting around, this seems to be the approximate skeleton, but I’m getting the error below simply trying to create the tableset. I have no idea what other assembly or using statement to add, aside from Erp.Contracts.BO.BomSearch, which I have already added.
The type or namespace name ‘BomSearchTableset’ could not be found (are you missing a using directive or an assembly reference?)
// Assemblies:
//  Erp.Contracts.BO.BomSearch
using (var bomTran = Ice.Assemblies.ServiceRenderer.GetService<Erp.Contracts.BomSearchSvcContract>(Db))
    string      vPartNum        = "MYPARTNUM";
    string      vRevision       = "A03";
    //var ds = new Erp.Tablesets.BomSearchTableset();
    Erp.Tablesets.BomSearchTableset ds = new BomSearchTableset();
    //bomTran.GetDatasetForTree(ref ds, vPartNum, vRevision, "", true, DateTime.Today, true);
    //ds.GetDatasetForTree(vPartNum, vRevision, "", true, DateTime.Today, true);
    if (ds != null)
        foreach (var row in ds.Tables[0].Rows)
            // todo
    else
In your line here:
You correctly use the full namespace for the left side of the assignment, but not the right. Either:
  1. Add Erp.Tablesets to your using statements and not worry about it again.
  2. Add Erp.Tablesets before BomSearchTableset every time you use it.
Ah thank you! Option 2 fixed it. For some reason, option 1 did not make any difference.
This doesn’t work?
Hmm, it is working now. I must have mistyped it. Thanks!
