Error during conversion from E10.2.500.32 to Kinetic 11.2.300.6
We receive the error:
Error Post Migration ICE_FKs.sql The ALTER TABLE statement conflicted with the FOREIGN KEY constraint “FK_UserTracing_SysUserFile”. The conflict occurred in database “DTS-Epi11”, table “Ice.SysUserFile”, column ‘UserID’.
alter table Ice.UserTracing
add constraint F
How do we track this down?
Look to see this query if you get any results (don’t mind the english there):
SELECT *
FROM ice.UserTracing
where ice.UserTracing.userid in (
Select t1.userid
from ice.UserTracing t1
Left Join ice.SysUserFile t2 on t2.UserID = t1.userid
where t2.UserID is null)
I get 3 results.
Okay, do you have active support Jeff? Like do you have a maintenance contract in place with Epicor?
Yes we do.
Will do. Thanks a lot.
Look up this PRB: PRB0190185 you can use that in the case you open.
Nice Jeff!
