Error in Customer Tracker - "value does not match the mask"
It is 9527.
You can check article # 4239ESC in the tips for the whole explanation.
----- Original Message -----
Sent: Thursday, July 10, 2008 3:13:29 PM (GMT-0800) America/Los_Angeles
Subject: RE: [Vantage] Error in Customer Tracker - "value does not match the mask"
We are getting that same message on a particular customer, too. Can you tell us what conversion you ran to correct this?
Thanks!
From: vantage@yahoogroups.com [mailto: vantage@yahoogroups.com ] On Behalf Of Jennifer George
Sent: Thursday, July 10, 2008 3:07 PM
Subject: Re: [Vantage] Error in Customer Tracker - "value does not match the mask"
Thanks, Robert!
After searching again on the Vantage site, I have found that I have to run a conversion program.
From: "Robert Brown" < robertb_versa@... <mailto:robertb_versa%40yahoo.com> >
Sent: Thursday, July 10, 2008 12:58:03 PM (GMT-0800) America/Los_Angeles
Looks like one of your customer records has a CustNum that doesn't conform to the column type (or perhaps object methods in the Tracker that manipulate the data in that column).
--- On Thu, 7/10/08 , Jennifer George < jgeorge@... <mailto:jgeorge%40heatcon.com> > wrote:
From: Jennifer George < jgeorge@... <mailto:jgeorge%40heatcon.com> >
Subject: [Vantage] Error in Customer Tracker - "value does not match the mask"
To: "vantage" < vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> >
Date: Thursday, July 10, 2008 , 3:28 PM
I am getting the following error on a customer tracker screen - only for one customer (at least as far as I can tell)
Anyone seen this? Or better yet, know how to resolve it?
Error Detail
Stack Trace
at Infragistics. Win.UltraWinMask edEdit.InputChar Base.set_ Char(Char value)
at Infragistics. Win.UltraWinMask edEdit.NumberSec tion.SetText( String text)
at Infragistics. Win.EditorWithMa sk.SetDoubleValu e(SectionsCollec tion sections, Double val, MaskInfo maskInfo)
at Infragistics. Win.EditorWithMa sk.SetDataValue( SectionsCollecti on sections, Type dataType, Object val, MaskInfo maskInfo)
at Infragistics. Win.UltraWinMask edEdit.EditInfo. SetValue( Object val)
at Infragistics. Win.UltraWinMask edEdit.EditInfo. set_Value( Object value)
at Infragistics. Win.EditorWithMa sk.set_Value( Object value)
at Infragistics. Win.UltraWinEdit ors.UltraNumeric Editor.set_ Value(Object value)
at Epicor.Mfg.UI. FrameWork. EpiNumericEditor .oDataView_ EpiViewNotificat ion(EpiDataView view, EpiNotifyArgs ar)
at Epicor.Mfg.UI. FrameWork. EpiViewNotificat ion.Invoke( EpiDataView view, EpiNotifyArgs args)
at Epicor.Mfg.UI. FrameWork. EpiDataView. Notify(EpiNotify Args args)
at Epicor.Mfg.UI. App.CustomerTrac ker.Transaction. GetCustomerData( String custNum)
Thank you in advance for the help!
jen
Error Detail
Stack Trace
at Infragistics.Win.UltraWinMaskedEdit.InputCharBase.set_Char(Char value)
at Infragistics.Win.UltraWinMaskedEdit.NumberSection.SetText(String text)
at Infragistics.Win.EditorWithMask.SetDoubleValue(SectionsCollection sections, Double val, MaskInfo maskInfo)
at Infragistics.Win.EditorWithMask.SetDataValue(SectionsCollection sections, Type dataType, Object val, MaskInfo maskInfo)
at Infragistics.Win.UltraWinMaskedEdit.EditInfo.SetValue(Object val)
at Infragistics.Win.UltraWinMaskedEdit.EditInfo.set_Value(Object value)
at Infragistics.Win.EditorWithMask.set_Value(Object value)
at Infragistics.Win.UltraWinEditors.UltraNumericEditor.set_Value(Object value)
at Epicor.Mfg.UI.FrameWork.EpiNumericEditor.oDataView_EpiViewNotification(EpiDataView view, EpiNotifyArgs ar)
at Epicor.Mfg.UI.FrameWork.EpiViewNotification.Invoke(EpiDataView view, EpiNotifyArgs args)
at Epicor.Mfg.UI.FrameWork.EpiDataView.Notify(EpiNotifyArgs args)
at Epicor.Mfg.UI.App.CustomerTracker.Transaction.GetCustomerData(String custNum)
jen
Does anyone know if it is possible to add a new tab to a tabbed form? If so where do I go?
Thanks!
Dale
To: "vantage" <vantage@yahoogroups.com>
Date: Thursday, July 10, 2008, 3:28 PM
Error Detail
Stack Trace
jen
In customization mode, use Sheet Wizard.
--- On Thu, 7/10/08, Dale R. Kalsow <dale.r.kalsow@...> wrote:
Subject: [Vantage] Adding a tab to a field
Date: Thursday, July 10, 2008, 3:56 PM
Thanks!
Dale
Thanks, Robert!
To: "vantage" < vantage@yahoogroups.com >
Error Detail
Stack Trace
jen
Thanks!
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Jennifer George
Thanks, Robert!
From: "Robert Brown" <robertb_versa@... <mailto:robertb_versa%40yahoo.com> >
Error Detail
Stack Trace
jen
