Hey,
I’m trying to get pending inspections in a customized dashboard. I’m getting an error upon execution of GetRows. Here’s part of the trace on Inspection Processing:
<businessObject>Erp.Proxy.BO.InspProcessingImpl</businessObject>
<methodName>GetRows</methodName>
<appServerUri>net.tcp://dnp-paepiapp/ERP10V/</appServerUri>
<returnType>Erp.Tablesets.InspProcessingTableset</returnType>
<localTime>11/27/2019 10:10:35:2873272 AM</localTime>
<threadID>1</threadID>
<executionTime total="2316" roundTrip="2158" channel="113" bpm="5" other="40" />
<retries>0</retries>
<parameters>
<parameter name="plOperation" type="System.Boolean"><![CDATA[False]]></parameter>
<parameter name="plMaterial" type="System.Boolean"><![CDATA[False]]></parameter>
<parameter name="plInventory" type="System.Boolean"><![CDATA[True]]></parameter>
<parameter name="plFirstArt" type="System.Boolean"><![CDATA[False]]></parameter>
<parameter name="plReceipt" type="System.Boolean"><![CDATA[False]]></parameter>
<parameter name="plRMA" type="System.Boolean"><![CDATA[False]]></parameter>
<parameter name="pcInspectorID" type="System.String"><![CDATA[]]></parameter>
<parameter name="pcCutOffDate" type="System.String"><![CDATA[]]></parameter>
<parameter name="whereClauseNonConf" type="System.String"><![CDATA[]]></parameter>
<parameter name="whereClauseFirstArt" type="System.String"><![CDATA[]]></parameter>
<parameter name="whereClauseRcvDtl" type="System.String"><![CDATA[]]></parameter>
<parameter name="whereClauseRMA" type="System.String"><![CDATA[]]></parameter>
<parameter name="whereClauseSelectedSerialNumbers" type="System.String"><![CDATA[]]></parameter>
<parameter name="whereClauseSNFormat" type="System.String"><![CDATA[]]></parameter>
<parameter name="whereClauseInspProcList" type="System.String"><![CDATA[]]></parameter>
<parameter name="sortBy" type="System.String"><![CDATA[PartNum]]></parameter>
<parameter name="pageSize" type="System.Int32"><![CDATA[100]]></parameter>
<parameter name="absolutePage" type="System.Int32"><![CDATA[0]]></parameter>
<parameter name="morePages" type="System.Boolean"><![CDATA[False]]></parameter>
<parameter name="CallContext" type="Ice.Bpm.Context.ContextDataSet">
<ContextDataSet xmlns="http://www.epicor.com/Ice/300/Bpm/Context">
<BpmData>
<SysRowID>00000000-0000-0000-0000-000000000000</SysRowID>
</BpmData>
</ContextDataSet>
Here’s the customization code:
private void btnSaveInspections_Click(object sender, System.EventArgs args)
var inspProcessingAdapter = ((InspProcessingAdapter)(this.csm.TransAdaptersHT["oTrans_inspAdapter"]));
bool morePages = false;
SearchOptions opts = new SearchOptions(SearchMode.AutoSearch);
opts.PreLoadSearchFilter = ""; //"InspectionPending='true' ";
opts.DataSetMode = DataSetMode.ListDataSet;
opts.NamedSearch.WhereClauses.Add("plOperation","FALSE");
opts.NamedSearch.WhereClauses.Add("plMaterial","FALSE");
opts.NamedSearch.WhereClauses.Add("plInventory","TRUE");
opts.NamedSearch.WhereClauses.Add("plFirstArt","FALSE");
opts.NamedSearch.WhereClauses.Add("plReceipt","FALSE");
opts.NamedSearch.WhereClauses.Add("plRMA","FALSE");
opts.NamedSearch.WhereClauses.Add("pcInspectorID","");
opts.NamedSearch.WhereClauses.Add("pcCutOffDate","");
opts.NamedSearch.WhereClauses.Add("whereClauseNonConf","");
opts.NamedSearch.WhereClauses.Add("whereClauseFirstArt","");
opts.NamedSearch.WhereClauses.Add("whereClauseRcvDtl","");
opts.NamedSearch.WhereClauses.Add("whereClauseRMA","");
opts.NamedSearch.WhereClauses.Add("whereClauseSelectedSerialNumbers","");
opts.NamedSearch.WhereClauses.Add("whereClauseSNFormat","");
opts.NamedSearch.WhereClauses.Add("whereClauseInspProcList","");
opts.NamedSearch.WhereClauses.Add("sortBy","PartNum");
opts.NamedSearch.WhereClauses.Add("pageSize","100");
opts.NamedSearch.WhereClauses.Add("absolutePage","0");
opts.NamedSearch.WhereClauses.Add("morePages","FALSE");
System.Data.DataSet dsInspProcessing = inspProcessingAdapter.GetRows(opts, out morePages); // *error occurs here*
inspProcessingAdapter.Dispose();
MessageBox.Show("count " + dsInspProcessing.Tables[0].Rows.Count.ToString());
Note all the WhereClause.Adds. I added these in a blind attempt to prevent this error:
Application Error
Exception caught in: App.DNP_NonConfInspProc.MainController.EP.Customization.DNP_NonConfInspProc.CustomCode.26
Error Detail
Message: Object reference not set to an instance of an object.
Program: App.DNP_NonConfInspProc.MainController.EP.Customization.DNP_NonConfInspProc.CustomCode.26.dll
Method: btnSaveInspections_Click
Client Stack Trace
at Script.btnSaveInspections_Click(Object sender, EventArgs args)
at System.Windows.Forms.Control.OnClick(EventArgs e)
at Infragistics.Win.Misc.UltraButtonBase.OnClick(EventArgs e)
at Ice.Lib.Framework.EpiButton.OnClick(EventArgs e)
at Infragistics.Win.Misc.UltraButton.OnMouseUp(MouseEventArgs e)
at Ice.Lib.Framework.EpiButton.OnMouseUp(MouseEventArgs e)
at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
at System.Windows.Forms.Control.WndProc(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
Of course, the InspProcessing adapter is added to the customization.
What, pray tell, might I be missing?
Joe
