Error in Generate PO Object Reference not Set in Epicor 10
Hello
When user do generate PO Suggestion it is behaving weird. When Generate PO it is giving Error like below-
After this, it is creating 2 PO one with correct Part and supplier and another PO with wrong Supplier and blank PartNum.
I have disable all BPM of Part, PO Suggestion and running in Base Mode even error is coming.
Any idea why it is behaving like this.
Thanks in advance.
can you show the screen “generate suggestion” with settings.
Hi Jarry,
From where i can find this settings of Generate Suggestion. In Company maintenance, didn’t found.
this one
Hi,
There is nothing related to this Purchase Suggestion. I am talking about Generating PO through New PO Suggestion screen. There after entering supplier, part, price etc tick Buy checkbox. Then from Action-- Generate PO-- and click ok.
After then it give above error. This is for 1 specific buyer only. For other buyer no error is coming. I am not getting why for 1 buyer it is giving error
Rgds,
Ajay
Is it possible that your buyer is in the wrong plant, or is not associated with the plant he’s buying for? Based on the error, it either doesn’t like the BuyerID or the PlantID.
Hi Kevin,
We have only 1 plant setup. So i think it is not issue of plant. Base on error, not able to find in which form/setup there is issue.
Hi
Is there any way to resolve this…
I am really not getting why this error is coming
