Try this instead of the Assign.
Run lib\UpdateTableBuffer.p(input BUFFER OrderRel:HANDLE, 'FirmRelease', "NO").
This sample is used to set the OrderRel.FirmRelease field to False. You may want to comment out the message section to see if that is your error.
--- In vantage@yahoogroups.com, "Cathy" <cathy@...> wrote:
> I am still missing the correct syntax. My BPM lets me validate the code
> but, when I try testing - I get an "Unexpected error - see appserver logs."
> It does not even display the "Setting Checkbox to False" - when I comment
> out the Assign JobOper01 = False - it will loop through and display all the
> Operations.
> Any suggestions?
> Thank you -
> define variable vSubject as character no-undo.
> For Each ttJobOper where ttJobOper.rowmod = 'U' and ttJobOper.OpComplete =
> True no-lock.
> For each JobOper where ttJobOper.Company = JobOper.Company
> and ttJobOper.JobNum = JobOper.JobNum:
> assign vSubject = "Setting Checkbox to False " + string(joboper.OprSeq) +
> '' + joboper.OpDesc + "Job Oper Complete " + string(joboper.OpComplete).
> {lib/publishinfomsg.i &infomsg = vSubject} .
> Assign JobOper.checkbox01 = False.
> End.
> End.
> From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of
> cathyattechnologicsys
> Sent: Monday, August 12, 2013 3:10 PM
> To: vantage@yahoogroups.com
> Subject: [Vantage] Re: Error Message on BPM
> Just shoot me - yes it is checkbox01.
> Now, I am getting an "Unexpected error - see appserver logs."
> --- In vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> , Jose
> Gomez <jose@> wrote:
> > You said checkbox= false... don't you mean checkbox01?
> > On Aug 12, 2013 5:50 PM, "cathyattechnologicsys" <cathy@>
> > wrote:
> > > I am writing a BPM - Data Directive - In Transaction on the Job
> Operation
> > > Table.
> > > I want to set checkbox01 to false on all operation when the operation
> > > complete checkbox is true and have a loop.
> > > The BPM is below but, I receive a message "checkbox matches multiple
> > > fields in JobOper. (3509)".
> > > It displays each record separately so, why can't it assign checkbox01 =
> > > false separately.
> > > What is the correct syntax? Your help is appreciated.
> > > True no-lock.
> > > End.
> > > End.
