--- In vantage@yahoogroups.com, Joe Englert <englertj@...> wrote:
> What if you remove the quotes around the "0" of your else. It might be confused about how to return a string or a number.
> From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Jose Gomez
> Sent: Tuesday, January 07, 2014 10:56 AM
> To: Vantage
> Subject: Re: [Vantage] Re: Error Message With BAQ
> Change the double quotes to single quotes and see if it helps.
> Jose C Gomez
> Software Engineer
> T: 904.469.1524 mobile
> E: jose@...<mailto:jose@...>
> http://www.josecgomez.com
> [http://www.josecgomez.com/images/linkedin.png%5d<http://www.linkedin.com/in/josecgomez> [http://www.josecgomez.com/images/facebook.png%5d <http://www.facebook.com/josegomez> [http://www.josecgomez.com/images/google.png%5d <http://www.google.com/profiles/jose.gomez> [http://www.josecgomez.com/images/twitter.png%5d <http://www.twitter.com/joc85> [http://www.josecgomez.com/images/wp.png%5d <http://www.josecgomez.com/professional-resume/> [http://www.josecgomez.com/images/rss.png%5d <http://www.josecgomez.com/feed/>
> Quis custodiet ipsos custodes?
> On Tue, Jan 7, 2014 at 10:52 AM, clederer@...<mailto:clederer@...> <clederer@...<mailto:clederer@...>> wrote:
> if UD01.Key4 = "Temp" then (UD01.Number01 + UD01.Number04 + UD01.Number07) else "0"
> I had it working and then lost the query in a database overwrite so I'm trying to remember what the query was before.
> --- In vantage@yahoogroups.com<mailto:vantage@yahoogroups.com>, Jose Gomez <jose@<mailto:jose@>> wrote:
> > What does your calculated field look like?
> > *Jose C Gomez*
> > *Software Engineer*
> > T: 904.469.1524<tel:904.469.1524> mobile
> > E: jose@
> > <http://www.linkedin.com/in/josecgomez> <http://www.facebook.com/josegomez>
> > <http://www.google.com/profiles/jose.gomez> <http://www.twitter.com/joc85>
> > *Quis custodiet ipsos custodes?*
> > On Tue, Jan 7, 2014 at 10:39 AM, clederer@ <
> > clederer@> wrote:
> > > "Table: , Level:, Type: , RowID: , Text: Business Query Execution error.
> > > Please contact your System Administrator."
> > > Receiving this error after I add a calculated field into a query. The
> > > query runs before I add the calculated field. After I add the calculated
> > > field I check the syntax and it says, "Syntax is OK" The format of the
> > > calculated field and the fields it is calculating are both 'decimals.' Not
> > > sure where there is a miscommunication.
Receiving this error after I add a calculated field into a query. The query runs before I add the calculated field. After I add the calculated field I check the syntax and it says, "Syntax is OK" The format of the calculated field and the fields it is calculating are both 'decimals.' Not sure where there is a miscommunication.
Jose C Gomez
On Tue, Jan 7, 2014 at 10:39 AM, clederer@... <clederer@...> wrote:
Â<div> <p>"Table: , Level:, Type: , RowID: , Text: Business Query Execution error. Please contact your System Administrator."<br>
</div> <div style="color:#fff;min-height:0;"></div>
> *Jose C Gomez*
> *Software Engineer*
> E: jose@...
Jose C Gomez
On Tue, Jan 7, 2014 at 10:52 AM, clederer@... <clederer@...> wrote:
Â<div> <p>if UD01.Key4 = "Temp" then (UD01.Number01 + UD01.Number04 + UD01.Number07) else "0"<br>
I had it working and then lost the query in a database overwrite so I'm trying to remember what the query was before.> *Jose C Gomez*
> *Software Engineer*
> E: jose@...
> On Tue, Jan 7, 2014 at 10:39 AM, clederer@… <
What if you remove the quotes around the “0” of your else. It might be confused about how to return a string or a number.
To: Vantage
Jose C Gomez
Software Engineer
T:
904.469.1524 mobile
> *Jose C Gomez*
> *Software Engineer*
> E: jose@...
