Error on Printing General Ledger Report
We’ve got the following error while printing general ledger report. Anyone has experience and please help.
Program Ice.Services.Lib.RunTask raised an unexpected exception with the following message: RunTask: [A]System.Action2[System.Data.SqlClient.SqlDataReader,System.Collections.Generic.List1[Erp.Internal.GL.GeneralLedger+GLAcctDispRow]] cannot be cast to [B]System.Action2[System.Data.SqlClient.SqlDataReader,System.Collections.Generic.List1[Erp.Internal.GL.GeneralLedger+GLAcctDispRow]]. Type A originates from ‘mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089’ in the context ‘LoadNeither’ at location ‘C:\Windows\Microsoft.Net\assembly\GAC_64\mscorlib\v4.0_4.0.0.0__b77a5c561934e089\mscorlib.dll’. Type B originates from ‘mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089’ in the context ‘LoadNeither’ at location ‘C:\Windows\Microsoft.Net\assembly\GAC_64\mscorlib\v4.0_4.0.0.0__b77a5c561934e089\mscorlib.dll’.
Stack Trace:
at Epicor.ServiceModel.Tableset.DataReaderToTableDelegateCache.GetItem[TData](SqlDataReader reader, Type tableType, IceColumnCollection columns) in C:_Releases\ICE\3.1.500.7\Source\Shared\Framework\Epicor.ServiceModel\Tableset\DataReaderToTableDelegateCache.cs:line 60
at Epicor.ServiceModel.Tableset.DBReaderAdapter.LoadFromReader[TData](SqlDataReader reader, List1 table, IceColumnCollection iceColumns) in C:\_Releases\ICE\3.1.500.7\Source\Shared\Framework\Epicor.ServiceModel\Tableset\DBReaderAdapter.cs:line 75 at Epicor.ServiceModel.Tableset.DBReaderAdapter.LoadFromReader[TData](SqlDataReader reader, List1 table) in C:_Releases\ICE\3.1.500.7\Source\Shared\Framework\Epicor.ServiceModel\Tableset\DBReaderAdapter.cs:line 62
at Epicor.ServiceModel.Tableset.DBReaderAdapter.LoadFromReader[TData](SqlDataReader reader) in C:_Releases\ICE\3.1.500.7\Source\Shared\Framework\Epicor.ServiceModel\Tableset\DBReaderAdapter.cs:line 28
at Ice.Lib.ExecuteQuery.executeQuery[TRow](String sqlQuery) in C:_Releases\ICE\3.1.500.7\Source\Server\Internal\Lib\Ice.Lib.Shared\ExecuteQuery\ExecuteQuery.cs:line 209
at Ice.Lib.ExecuteQuery.Run[TRow](String[] pcTableName, String[] pcEFL, String[] pcFieldName, String[] pcJoinType, String[] pcWhereClause, String pcOrderBy, Int32 piRowIdBuffer, List1 hResultTable, String& pcErrorMsg, Boolean includeUDFields) in C:\_Releases\ICE\3.1.500.7\Source\Server\Internal\Lib\Ice.Lib.Shared\ExecuteQuery\ExecuteQuery.cs:line 152 at Erp.Internal.GL.GeneralLedger.BuildTempTables() in c:\_Releases\ERP\RL10.1.500\Source\Server\Internal\GL\GeneralLedger\GeneralLedger.cs:line 693 at Erp.Internal.GL.GeneralLedger.RunProcess(Int64 instanceTaskNum, String outputFileName) in c:\_Releases\ERP\RL10.1.500\Source\Server\Internal\GL\GeneralLedger\GeneralLedger.cs:line 476 at Ice.Hosting.TaskCaller.InnerExecuteTask(IceDataContext newContext) in C:\_Releases\ICE\3.1.500.7\Source\Framework\Epicor.Ice\Hosting\TaskCaller\TaskCaller.cs:line 93 at Ice.Hosting.TaskCaller.ExecuteTask() in C:\_Releases\ICE\3.1.500.7\Source\Framework\Epicor.Ice\Hosting\TaskCaller\TaskCaller.cs:line 54 at Ice.Lib.RunTask.BpmFriendlyTaskLauncher.Run(String sessionIdPrefix, IceContext db, Action taskRunner) in C:\_Releases\ICE\3.1.500.7\Source\Server\Services\Lib\RunTask\BpmFriendlyTaskLauncher.cs:line 63 at Ice.Services.Lib.RunTaskSvc.InnerRunTask(Int64 ipTaskNum, Boolean suppressTransaction) in C:\_Releases\ICE\3.1.500.7\Source\Server\Services\Lib\RunTask\RunTask.cs:line 526 at Ice.Services.Lib.RunTaskSvc.InnerRunTask(Int64 ipTaskNum, Boolean suppressTransaction) in C:\_Releases\ICE\3.1.500.7\Source\Server\Services\Lib\RunTask\RunTask.cs:line 526 at Ice.Services.Lib.RunTaskSvcFacade.RunTask(Int64 ipTaskNum) in C:\_Releases\ICE\3.1.500.7\Source\Server\Services\Lib\RunTask\RunTaskSvcFacade.cs:line 87 at SyncInvokeRunTask(Object , Object[] , Object[] ) at System.ServiceModel.Dispatcher.SyncMethodInvoker.Invoke(Object instance, Object[] inputs, Object[]& outputs) at Epicor.Hosting.OperationBoundInvoker.InnerInvoke(Object instance, Func2 func) in C:_Releases\ICE\3.1.500.7\Source\Framework\Epicor.System\Hosting\OperationBoundInvoker.cs:line 59
at Epicor.Hosting.OperationBoundInvoker.Invoke(Object instance, Func2 func) in C:\_Releases\ICE\3.1.500.7\Source\Framework\Epicor.System\Hosting\OperationBoundInvoker.cs:line 28 at Epicor.Hosting.Wcf.EpiOperationInvoker.Invoke(Object instance, Object[] inputs, Object[]& outputs) in C:\_Releases\ICE\3.1.500.7\Source\Framework\Epicor.System\Hosting\Wcf\EpiOperationInvoker.cs:line 23 at System.ServiceModel.Dispatcher.DispatchOperationRuntime.InvokeBegin(MessageRpc& rpc) at System.ServiceModel.Dispatcher.ImmutableDispatchRuntime.ProcessMessage5(MessageRpc& rpc) at System.ServiceModel.Dispatcher.ImmutableDispatchRuntime.ProcessMessage11(MessageRpc& rpc) at System.ServiceModel.Dispatcher.MessageRpc.Process(Boolean isOperationContextSet) at System.ServiceModel.Dispatcher.ChannelHandler.DispatchAndReleasePump(RequestContext request, Boolean cleanThread, OperationContext currentOperationContext) at System.ServiceModel.Dispatcher.ChannelHandler.HandleRequest(RequestContext request, OperationContext currentOperationContext) at System.ServiceModel.Dispatcher.ChannelHandler.AsyncMessagePump(IAsyncResult result) at System.ServiceModel.Dispatcher.ChannelHandler.OnAsyncReceiveComplete(IAsyncResult result) at System.Runtime.Fx.AsyncThunk.UnhandledExceptionFrame(IAsyncResult result) at System.Runtime.AsyncResult.Complete(Boolean completedSynchronously) at System.ServiceModel.Channels.SecurityChannelListener1.ReceiveItemAndVerifySecurityAsyncResult`2.InnerTryReceiveCompletedCallback(IAsyncResult result)
at System.ServiceModel.Channels.TransportDuplexSessionChannel.TryReceiveAsyncResult.OnReceive(IAsyncResult result)
at System.ServiceModel.Channels.SynchronizedMessageSource.ReceiveAsyncResult.OnReceiveComplete(Object state)
at System.ServiceModel.Channels.SessionConnectionReader.OnAsyncReadComplete(Object state)
at System.Net.LazyAsyncResult.Complete(IntPtr userToken)
at System.Net.LazyAsyncResult.ProtectedInvokeCallback(Object result, IntPtr userToken)
at System.Net.Security.NegotiateStream.ProcessFrameBody(Int32 readBytes, Byte[] buffer, Int32 offset, Int32 count, AsyncProtocolRequest asyncRequest)
at System.Net.Security.NegotiateStream.ReadCallback(AsyncProtocolRequest asyncRequest)
at System.Net.AsyncProtocolRequest.CompleteRequest(Int32 result)
at System.Net.FixedSizeReader.CheckCompletionBeforeNextRead(Int32 bytes)
at System.Net.FixedSizeReader.ReadCallback(IAsyncResult transportResult)
at System.ServiceModel.Channels.ConnectionStream.IOAsyncResult.OnAsyncIOComplete(Object state)
at System.Net.Sockets.SocketAsyncEventArgs.OnCompleted(SocketAsyncEventArgs e)
at System.Net.Sockets.SocketAsyncEventArgs.FinishOperationSuccess(SocketError socketError, Int32 bytesTransferred, SocketFlags flags)
at System.Net.Sockets.SocketAsyncEventArgs.CompletionPortCallback(UInt32 errorCode, UInt32 numBytes, NativeOverlapped* nativeOverlapped)
at System.Threading._IOCompletionCallback.PerformIOCompletionCallback(UInt32 errorCode, UInt32 numBytes, NativeOverlapped* pOVERLAP)
Is this still an issue?
The error is odd as it is saying that it can’t convert an object to the same object.
Have you recycled the App Pool?
great solution!
