I would take the simple approach first which would be to recopy the
client803 folder on the client machine.
Good Luck
vantage@yahoogroups.com [mailto:
vantage@yahoogroups.com] On Behalf
Of vantage803
Sent: Wednesday, May 09, 2007 9:03 AM
To:
Subject: [Vantage] Error on Specific Client Machine v8.03.305F Cannot
access AR-Tracker
All of a sudden I have a client not able to load their "AR-Tracker"
But if I log-In on my machine as that specific user everything is fine.
I also attempted to use my credentials on that specific clients machine
and it failed as well. I get the following errors, has anyone run into
this before? If so any help would be appreciated!
Thanks in Advance
Error Detail
Strong name validation failed for
assembly 'Epicor.Mfg.AD.ARInvoiceUpdt'.
Stack Trace
at Epicor.Mfg.UI.App.ARInvoiceUpdtEntry.Transaction.TransactionLoad()
at Epicor.Mfg.UI.FrameWork.EpiTransaction.createTransaction()
After accepting Error a 2nd one appears
Error Detail
Cannot access this menu item: Invoice Tracker
Inner Exception
Inner Stack Trace
at Epicor.Mfg.UI.FrameWork.EpiTransaction..ctor(Object Sender)
at Epicor.Mfg.UI.FrameWork.EpiMultiViewTransaction..ctor(Object
Sender)
at Epicor.Mfg.UI.App.ARInvoiceUpdtEntry.Transaction..ctor(Object
Sender)
at Epicor.Mfg.UI.App.Launch.InitializeLaunch()
at Epicor.Mfg.UI.FrameWork.EpiBaseLaunch.lShow(Object args, DataSet
dsMenuItem)
at Epicor.Mfg.UI.FrameWork.FormFunctions.Launch(Session session,
DataRow menuRow)
at Epicor.Mfg.UI.Startup.launchUIApp(MenuRow menuRow)
-Joe
