Error only with Project Manager task
User logs in, tries to open Project Manager and the following errors appear
( please note, if user logs in at another workstation, it works fine )
Application Error
Exception caught in: mscorlib
Error Detail
Message: The given key was not present in the dictionary.
Program: CommonLanguageRuntimeLibrary
Method: get_Item
Client Stack Trace
at System.Collections.Generic.Dictionary`2.get_Item(TKey key)
at Erp.UI.App.ProjectEntry.Transaction.TransactionLoad()
at Ice.Lib.Framework.EpiTransaction.createTransaction()
After hitting OK this error appears…
Application Error
Error Detail
Message: Cannot access this menu item: Project Entry
Inner Exception Message: The given key was not present in the dictionary.
Program:
Method:
Inner Exception
at Ice.Lib.Framework.EpiTransaction…ctor(Object Sender)
at Erp.UI.App.ProjectEntry.Transaction…ctor(Object Sender)
at Ice.Lib.App.Launch.InitializeLaunch()
at Ice.Lib.Framework.EpiBaseLaunch.lShow(Object args, DataSet dsMenuItem)
at Ice.Lib.Framework.FormFunctions.Launch(Session session, DataRow menuRow, Object lfo)
at Ice.Lib.Startup.LaunchUIApp(MenuRow menuRow, Session session, Form& form, Object lfo)
@rfarrar74
Try after deleting the Epicor client cache folder
Update -
Removing and reinstalling the Client fixed the issue.
