Hey Everyone! We’re running into an error when trying to receive a shipment. The PO is using “Standard” as a purchase type, and the receiving lady had just received another PO right before this one which was also “Standard”. I attempted to create a new generic purchase type as referenced Error in receipt entry - Yahoo Archive - Epicor User Help Forum but that didn’t seem to help. Any assistance is greatly appreciated, error text below:
Purchase Type Code references invalid value.
Error Detail
Description: Purchase Type Code references invalid value.
Program: Epicor.Ice.dll
Method: ValidateReferentialIntegrity
Line Number: 589
Column Number: 21
Table: RcvDtl
Field: PurchCode
Server Trace Stack: at Ice.Core.BizRuleEngine.ValidateReferentialIntegrity() in C:_Releases\ICE\RL3.2.200.0\Source\Framework\Epicor.Ice\BizRuleEngine\BizRuleEngine.cs:line 589
at Ice.Core.BizRuleEngine.ValidateRow() in C:_Releases\ICE\RL3.2.200.0\Source\Framework\Epicor.Ice\BizRuleEngine\BizRuleEngine.cs:line 179
at Ice.Core.BizRuleEngine.Validate(IceRow oldRow, IceRow newRow, LinqRow curRow) in C:_Releases\ICE\RL3.2.200.0\Source\Framework\Epicor.Ice\BizRuleEngine\BizRuleEngine.cs:line 124
at Erp.Services.BO.ReceiptSvc.CommitRcvDtl(Int32 vendorNum, String purPoint, String packSlip, ReceiptTableset& ds) in C:_Releases\ERP\UD10.2.200.20\Source\Server\Services\BO\Receipt\Receipt.cs:line 20739
at Erp.Services.BO.ReceiptSvcFacade.CommitRcvDtl(Int32 vendorNum, String purPoint, String packSlip, ReceiptTableset& ds) in C:_Releases\ERP\UD10.2.200.20\Source\Server\Services\BO\Receipt\ReceiptSvcFacade.cs:line 5435
at SyncInvokeCommitRcvDtl(Object , Object[] , Object[] )
at System.ServiceModel.Dispatcher.SyncMethodInvoker.Invoke(Object instance, Object[] inputs, Object[]& outputs)
at Epicor.Hosting.OperationBoundInvoker.InnerInvoke(Object instance, Func2 func) in C:\_Releases\ICE\ICE3.2.200.20\Source\Framework\Epicor.System\Hosting\OperationBoundInvoker.cs:line 59 at Epicor.Hosting.OperationBoundInvoker.Invoke(Object instance, Func
2 func) in C:_Releases\ICE\ICE3.2.200.20\Source\Framework\Epicor.System\Hosting\OperationBoundInvoker.cs:line 28
at Epicor.Hosting.Wcf.EpiOperationInvoker.Invoke(Object instance, Object[] inputs, Object[]& outputs) in C:_Releases\ICE\ICE3.2.200.20\Source\Framework\Epicor.System\Hosting\Wcf\EpiOperationInvoker.cs:line 23
at System.ServiceModel.Dispatcher.DispatchOperationRuntime.InvokeBegin(MessageRpc& rpc)
at System.ServiceModel.Dispatcher.ImmutableDispatchRuntime.ProcessMessage5(MessageRpc& rpc)
at System.ServiceModel.Dispatcher.ImmutableDispatchRuntime.ProcessMessage11(MessageRpc& rpc)
at System.ServiceModel.Dispatcher.MessageRpc.Process(Boolean isOperationContextSet)
at System.ServiceModel.Dispatcher.ChannelHandler.DispatchAndReleasePump(RequestContext request, Boolean cleanThread, OperationContext currentOperationContext)
at System.ServiceModel.Dispatcher.ChannelHandler.HandleRequest(RequestContext request, OperationContext currentOperationContext)
at System.ServiceModel.Dispatcher.ChannelHandler.AsyncMessagePump(IAsyncResult result)
at System.ServiceModel.Dispatcher.ChannelHandler.OnAsyncReceiveComplete(IAsyncResult result)
at System.Runtime.Fx.AsyncThunk.UnhandledExceptionFrame(IAsyncResult result)
at System.Runtime.AsyncResult.Complete(Boolean completedSynchronously)
at System.ServiceModel.Channels.SecurityChannelListener1.ReceiveItemAndVerifySecurityAsyncResult
2.InnerTryReceiveCompletedCallback(IAsyncResult result)
at System.ServiceModel.Channels.TransportDuplexSessionChannel.TryReceiveAsyncResult.OnReceive(IAsyncResult result)
at System.ServiceModel.Channels.SynchronizedMessageSource.ReceiveAsyncResult.OnReceiveComplete(Object state)
at System.ServiceModel.Channels.SessionConnectionReader.OnAsyncReadComplete(Object state)
at System.Net.LazyAsyncResult.Complete(IntPtr userToken)
at System.Net.LazyAsyncResult.ProtectedInvokeCallback(Object result, IntPtr userToken)
at System.Net.Security.NegotiateStream.ProcessFrameBody(Int32 readBytes, Byte[] buffer, Int32 offset, Int32 count, AsyncProtocolRequest asyncRequest)
at System.Net.Security.NegotiateStream.ReadCallback(AsyncProtocolRequest asyncRequest)
at System.Net.AsyncProtocolRequest.CompleteRequest(Int32 result)
at System.Net.FixedSizeReader.CheckCompletionBeforeNextRead(Int32 bytes)
at System.Net.FixedSizeReader.ReadCallback(IAsyncResult transportResult)
at System.ServiceModel.Channels.ConnectionStream.IOAsyncResult.OnAsyncIOComplete(Object state)
at System.Net.Sockets.SocketAsyncEventArgs.OnCompleted(SocketAsyncEventArgs e)
at System.Net.Sockets.SocketAsyncEventArgs.FinishOperationSuccess(SocketError socketError, Int32 bytesTransferred, SocketFlags flags)
at System.Net.Sockets.SocketAsyncEventArgs.CompletionPortCallback(UInt32 errorCode, UInt32 numBytes, NativeOverlapped* nativeOverlapped)
at System.Threading._IOCompletionCallback.PerformIOCompletionCallback(UInt32 errorCode, UInt32 numBytes, NativeOverlapped* pOVERLAP)
Client Stack Trace
at Epicor.ServiceModel.Channels.ImplBase`1.ShouldRethrowNonRetryableException(Exception ex, DataSet[] dataSets)
at Erp.Proxy.BO.ReceiptImpl.CommitRcvDtl(Int32 vendorNum, String purPoint, String packSlip, ReceiptDataSet ds)
at Erp.Adapters.ReceiptAdapter.CommitRcvDtl(Int32 vendorNum, String purPoint, String packSlip)
