Error starting logging to Vantage 8.03.409c
We are running Progress as our database.
--- In vantage@yahoogroups.com, "Lisser, Jennifer" <Jennifer.Lisser@...> wrote:
> Michael,
> I see you are running Progress 10.1B SP3 HF33, but are you running Progress or SQL as your database? If SQL, I got the pipe to server broken because I didn't have "Named Pipes" enabled in the SQL Server Configuration Manager.
> Jenn
Howdy folks,
Ok, I installed Vantage on test server all the way to version 409C. Went through the installation guides, restored a copy of db to it, truncated the bi. Database starts fine in Progress explorer. App servers start fine. I enter my username and password, click ok and receive the error:
The type initializer for 'Progress.Open4GL.RunTimeProperties' threw an exception.
I am using Progress version 10.1B SP3 with hot 33 as well.
Any ideas?
Regards,
Michael
Anything in the server logs?
*Jose C Gomez*
*Software Engineer*
*checkout my new blog <http://www.usdoingstuff.com> *
*T: 904.469.1524 mobile
E: jose@...
http://www.josecgomez.com
On Wed, Aug 3, 2011 at 9:37 AM, michael.hutcheson@... <
michael.hutcheson@...> wrote:
> Howdy folks,
> exception.
> Any ideas?
> Regards,
> Michael
Hello,
Yes, I receive the below:
IOException reading message from server : java.io.EOFException: pipe to server broken (8117)
Exception unbinding broker (not bound) : MfgSys803 (8525)
Which translates to:
CAUSE:
The Database start up parameter -n is set to a lower value than the
AppServer Server "Pool Range" setting.
FIX:
Set the Pool Range Appserver Server settings accordingly to the
Database's max number of clients setting (-n)
CAUSE:
Server startup parameters ( connection parameters to the database) for
the AppServer is set using -pf and the path to the .pf file. The .pf
file referenced in the ubroker.properties file was missing.
FIX:
Restore the .pf file to the expected location.
- I've checked the pool range and cannot see anything wrong - This is using a default install as well.
- Again, the .pf file looks ok - all the correct directories etc...
Regards,
Michael
> *Jose C Gomez*
> *Software Engineer*
> E: jose@...
> > Howdy folks,
> > exception.
> > Any ideas?
> > Regards,
> > Michael
Michael,
Jenn
