Hello All,
I have a request to add a web page to MES.
I made a dashboard and added the web page to it as a url view. It works fine.
Using the new sheet wizard in MES, I added a sheet for that dashboard to display.
When I click on the tab it displays the error below.
Is there any way I can get this to work?
Thanks!
Application Error
Exception caught in: Ice.Lib.EpiClientLib
Error Detail
Message: The process caller failed to invoke method PerformSearch in Ice.Lib.Searches.EpiSearchEngine in Ice.Lib.EpiClientLib.dll
Inner Exception Message: Exception has been thrown by the target of an invocation.
Program: Ice.Lib.EpiClientLib.dll
Method: InvokeReflectedMethod
Client Stack Trace
at Ice.Lib.Framework.PCallReflector.InvokeReflectedMethod(MethodInfo Method, Object Object, Object[] MethodParams, String className, String assemblyName)
at Ice.Lib.Framework.PCallReflector.LaunchDotNet(String assemblyName, String className, Hashtable ctorList, String methodName, Hashtable methodList)
Inner Exception
Inner Stack Trace
at System.RuntimeMethodHandle.InvokeMethod(Object target, Object[] arguments, Signature sig, Boolean constructor)
at System.Reflection.RuntimeMethodInfo.UnsafeInvokeInternal(Object obj, Object[] parameters, Object[] arguments)
at System.Reflection.RuntimeMethodInfo.Invoke(Object obj, BindingFlags invokeAttr, Binder binder, Object[] parameters, CultureInfo culture)
Inner Exception
Error accessing the database: Incorrect syntax near ‘)’.
Inner Stack Trace
at Ice.Lib.Searches.EpiSearchEngine.invokeSearch(String AdapterName, SearchOptions opts)
at Ice.Lib.Searches.EpiSearchEngine.InvokeSearch(String AdapterName, String Mode, Boolean singleSelect, Boolean showForm, String preFilter, String like, Object sender)
at Ice.Lib.Searches.EpiSearchEngine.PerformSearch(String AdapterName, String Mode, String preFilter, Object sender)
Inner Exception
