I'm not that sure about changing it but there is a - L parameter in the
startup.pf file located in your prgoress folder. to check what it's set at
you right click on the startup file and select edit. About halfway down
there should be a - L you could try increasing the number. But you have to
shutdown and restart the database for it to take affect.
But I would still recomend you ask a Vantage techy about it. I have hato
change the -n nuber before and that's how I knew where the -L was.
Jeff Blair
C.N.C. Programmer
Network Administrator
Advanced Manufacturing Technologies, Inc.
316-943-0251
316-941-9472 fax
Visit our website at: www.advmantec.com
Jeff Blair
C.N.C. Programmer
316-943-0251
316-941-9472 fax
