When scheduling jobs we get the following set of error messages:
At the beginning of the scheduling process (immediately after clicking
"Schedule - Job Scheduling..."):
"Specified ActiveX control is not registered or the .ocx
file was moved from where it was registered.
Error occurred in procedure: control_load jc/jcsch-dg.w
(6087)".
After each operation is scheduled, the following two messages appeared
separated by the "OK" button:
"Error occurred while accessing component property/method:
ctMeter.
Unknown name.
Error code: 0x80020006 DISP-STATUS jc/jcsch-dg.w (5890)";
click "OK"
"Unable to set com-handle properly (5677)"; click "OK".
Then Vantage proceeds with the next operation
I did not see any problem with the schedule itself, all dates seem to be
fine. This is just annoying inconvenience.
Do you have any suggestions how to resolve the problem?
We use V3.0
Thank you
Vladimir Tigay
WLS Stamping Co.
216-271-5100 x3020
(6087)".
ctMeter.
Unknown name.
click "OK"
We use V3.0
Thank you
Vladimir Tigay
WLS Stamping Co.
216-271-5100 x3020
