I am getting the following error message while creating revisions with the DMT: “PartRev Msg: The following fields may not be different from the Base Revision values:
Effective Date”
The frustrating part is that I have used the same template for months and never had an issue. Aside for an update to the DMT recently, I don’t know of anything else that changed.
I was able to load the data with an older version of the DMT but I am not super comfortable with this as (hopefully) new versions bring fixes and I might be missing on them if I keep an old version.
And normally I would agree with you. But it you search around a bit, you will see there are pretty significant problems with the newest versions of DMT. One thread here will give you an idea.
This is good information, thank you. That is why I put (hopefully) between parenthesis
I am keeping a copy of my good old version 40.0.25 in a safe place if I don’t get those templates to work with the latest version.
