Errors no longer show which Method Directive
I know when I used to get errors for a Method Directive, it would tell me which one it was but they don’t appear to do that now. Is this a setting I changed without realizing it, or is it now a thing to not show?
Old error detail:
Correlation ID:  acbabb11-be8d-4b04-8c15-0d27996cfff4
Description:  BPM runtime caught an unexpected exception of 'NullReferenceException' type.
See more info in the Inner Exception section of Exception Details.
Program:  Erp.BO.APInvoice.UpdateMaster.dll
Method:  A003_CustomCodeAction
Original Exception Type:  NullReferenceException
Server Trace Stack:     at Epicor.Customization.Bpm.BO.UpdateMasterPreProcessingDirective_tedSupplierCheck_9DF59B84ACBA42369371C9F46A7AFF79.A003_CustomCodeAction()
   at Epicor.Customization.Bpm.BO.UpdateMasterPreProcessingDirective_tedSupplierCheck_9DF59B84ACBA42369371C9F46A7AFF79.ExecuteCore(Int32 step)
   at Epicor.Customization.Bpm.DirectiveBase`2.Execute() in C:\_releases\ICE\ICE4.2.300.0\Source\Server\Internal\Lib\Epicor.Customization.Bpm\DirectiveBase.Generic.cs:line 330
   at Epicor.Customization.Bpm.DirectiveBase`2.Execute(TParam parameters) in C:\_releases\ICE\ICE4.2.300.0\Source\Server\Internal\Lib\Epicor.Customization.Bpm\DirectiveBase.Generic.cs:line 222
New version:
The table TempTable.APInvHed has more than one record
Error Detail
Correlation ID:  521397fc-f602-4ab5-b951-641eee2bb064
Message No.: 1
Description:  The table TempTable.APInvHed has more than one record
Program:  Epicor.Customization.dll
Method:  GetSingleRow
Line Number:  68
Column Number:  17
Table:  TempTable.APInvHed
Message No.: 2
Line Number:  68
Column Number:  17
Client Stack Trace
   at Ice.Cloud.ProxyBase`1.CallWithCommunicationFailureRetry(String methodName, ProxyValuesIn valuesIn, ProxyValuesOut valuesOut, RestRpcValueSerializer serializer)
   at Ice.Cloud.ProxyBase`1.CallWithMultistepBpmHandling(String methodName, ProxyValuesIn valuesIn, ProxyValuesOut valuesOut, Boolean useSparseCopy)
   at Ice.Cloud.ProxyBase`1.Call(String methodName, ProxyValuesIn valuesIn, ProxyValuesOut valuesOut, Boolean useSparseCopy)
   at Erp.Proxy.BO.APInvoiceImpl.UpdateMaster(APInvoiceDataSet ds, String cGroupID, String cTableName, Boolean runChkCPay, Boolean runChkBankRef, Boolean runChkRevChrg, Boolean suppressUserPrompts, Decimal& grpTotalInvAmt, Boolean& requiresUserInput, String& opMessage, String& opMsgChkBankRef, String& opChkRevMsg, Boolean& lEnableGenLegalNum, Boolean& lUpdateRan, String& opDUAMsg)
   at Erp.Adapters.APInvoiceAdapter.UpdateMaster(String cGroupID, String cTableName, Boolean runChkCPay, Boolean runChkBankRef, Boolean runChkRevChrg, Boolean suppressUserPrompts, Decimal& grpTotalInvAmt, Boolean& requiresUserInput, String& opMessage, String& opMsgChkBankRef, String& opChkRevMsg, Boolean& lEnableGenLegalNum, Boolean& lUpdateRan, String& opDUAMsg)
   at Erp.UI.App.APInvoiceEntry.Transaction.Update(Boolean refreshGroup)
It is like this now. If you want more information about the error message, you need to check the event log viewer of the server under the “Application and Server Log” section.
Unfortunately, while I do have errors in there (one I wasn’t aware of was a BAQ I had forgotten to share which never showed client side as an issue), the one that this referred to is strangely absent. I figured out which one it was and resolved the actual error, but the lack of direction from the error message is a problem and to hear that this is the way it is now is disheartening.
Agree. I would suggest to use “Performance and Diagnostic Tool” > Server Diagnostic to dig for more details on custom work issues.
