Event Handlers Blank Title 108418
Excellent!
On Thu, Mar 15, 2012 at 1:30 PM, Ted Koch <tkoch77@...> wrote:
> Ah okay, I understand. That worked great, thank you John!
> From: John Driggers <waffqle@...>
> To: vantage@yahoogroups.com
> Sent: Thursday, March 15, 2012 1:09 PM
> Subject: Re: [Vantage] Event Handlers
> Ok, what you need to do is pull the info you want from the dataview instead
> of the control.
> It should look something like this:
> dim variable As String = view.dataView(args.Row)("FieldName")
> That will pull the data that the notification is firing against.
> On Thu, Mar 15, 2012 at 11:44 AM, Ted Koch <tkoch77@...> wrote:
> > Not not seeing it, when it is being triggered I'm getting the data before
> > the initialize has completed, not what is on the screen after. I dont
> know
> > if you have time, but if you try this you can see what is happening.
> > Private Sub edvSugPoDtl_EpiViewNotification(ByVal view As EpiDataView,
> > ByVal args As EpiNotifyArgs)
> > ' ** Argument Properties and Uses **
> > If (args.NotifyType = EpiTransaction.NotifyType.Initialize) Then
> > dim txtAsmSeq as epiNumericeditor =
> Ctype(csm.GetNativeControlReference("5621d1ff-7728-456c-a3c4-724b67b69cbc"),
> > epinumericeditor)
> > msgbox(txtasmseq.text)
> > End If
> > End Sub
> > Sent: Thursday, March 15, 2012 11:22 AM
> > You should be able to use the EpiView. The data you need should be
> visible
> > by the time the event fires. Are you not seeing it?
> > On Thu, Mar 15, 2012 at 10:32 AM, Ted Koch <tkoch77@...> wrote:
> > > Thanks for the input Rob, I'll keep trying different ways until I get
> it.
> > > From: Rob Bucek <rbucek@...>
> > > To: "vantage@yahoogroups.com" <vantage@yahoogroups.com>
> > > Sent: Thursday, March 15, 2012 10:26 AM
> > > Subject: RE: [Vantage] Event Handlers
> > > I thought I remember reading another post about capturing where the
> focus
> > > was on the tree... if you could do that then maybe you could refresh or
> > > notify the form, or even your embedded dashboard (if that's what your
> > grid
> > > is..) that code would be beyond my experience though.
> > > Rob Bucek
> > > Production Control Manager
> > > PH: (715) 284-5376 ext 311
> > > Mobile: (715)896-0590
> > > FAX: (715)284-4084
> > > [Description: cid:1.234354861@...]<
> > > http://www.dsmfg.com/>
> > > (Click the logo to view our site)<http://www.dsmfg.com/>
> > > From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On
> Behalf
> > > Of Ted Koch
> > > Sent: Thursday, March 15, 2012 9:19 AM
> > > I did that, and the only one I am able to get a messagebox to show up
> > when
> > > clicking through the tree nodes is with EpiViewNotification, message
> box
> > > appears saying initialize. The only problem with this is there is no
> > AFTER
> > > EpiViewNotification. I am trying to update a datagrid I have on a tab,
> > and
> > > it keys off what is in the job fields on that form. So after the new
> > > information is loaded into the form i want to use that information to
> > > update the datagrid.
> > > I tried using this but it uses what is in the form prior to the
> > > EpiViewNotification updating the UI.
> > > Search()
> > > End If
> > > End Sub
> > > From: Rob Bucek <rbucek@...<mailto:rbucek%40dsmfg.com>>
> > > To: "vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>" <
> > > vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>>
> > > Sent: Thursday, March 15, 2012 9:57 AM
> > > I haven't tried to customize that form but sometimes when ive been
> > > searching for a trigger I use the following in various forms..try
> before
> > > and after.. uncomment the messagebox.show, if the method is being
> exposed
> > > to the client (I think) youll get a message box as you step yourself
> > > through the form..some forms don't show anything, which makes it
> tough..
> > > Private Sub oTrans_adapter_BeforeAdapterMethod(ByVal
> > > sender As object, ByVal args As BeforeAdapterMethodArgs) Handles
> > > oTrans_adapter.BeforeAdapterMethod
> > > '// ** Argument Properties and Uses **
> > > '// args.MethodName, args.Cancel
> > > 'Add Event Handler Code
> > > 'MessageBox.Show(args.MethodName) ' use this to find
> > > method
> > > Most of the event handlers from the wizard give you some clues about
> > > checking for events.. like the epiviewnotification (the fire hose) you
> > > could try messagebox.show (args.notifytpe)
> > > HTH
> > > Rob Bucek
> > > FAX: (715)284-4084
> > > [Description: cid:1.234354861@...<mailto:
> > > 1.234354861%40web65412.mail.ac4.yahoo.com>]<http://www.dsmfg.com/>
> > > From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>
> [mailto:
> > > vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>] On Behalf
> Of
> > > tkoch77
> > > Sent: Thursday, March 15, 2012 7:57 AM
> > > To: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>
> > > Subject: [Vantage] Event Handlers
> > > I don't know what I'm missing. I'm on New PO Suggestion and trying to
> > > trigger an event AFTER I click on a material or subcontract item and
> the
> > > form is repopulated. What transaction event handler would I use to
> > trigger
> > > something?
> > > Thanks,
> > > Ted
> > > Useful links for the Yahoo!Groups Vantage Board are: ( Note: You must
> > > have already linked your email address to a yahoo id to enable access.
> > > (1) To access the Files Section of our Yahoo!Group for Report Builder
> and
> > > Crystal Reports and other 'goodies', please goto:
> > > http://groups.yahoo.com/group/vantage/files/.<
> > > http://groups.yahoo.com/group/vantage/files/>
> > > (2) To search through old msg's goto:
> > > http://groups.yahoo.com/group/vantage/messages
> > > (3) To view links to Vendors that provide Vantage services goto:
> > > http://groups.yahoo.com/group/vantage/linksYahoo! Groups Links
> and
> > *John Driggers*
> > *High End Dev, System Design, Profit Drinking*
> > **:: 904.404.9233*
> > *:: waffqle@...*
> > *:: NO FAXES*
> > have already linked your email address to a yahoo id to enable access. )
> > (1) To access the Files Section of our Yahoo!Group for Report Builder and
> *John Driggers*
> **:: 904.404.9233*
> *:: waffqle@...*
> *:: NO FAXES*
*John Driggers*
**:: 904.404.9233*
*:: waffqle@...*
*:: NO FAXES*
I don't know what I'm missing. I'm on New PO Suggestion and trying to trigger an event AFTER I click on a material or subcontract item and the form is repopulated. What transaction event handler would I use to trigger something?
Ted
I haven't tried to customize that form but sometimes when ive been searching for a trigger I use the following in various forms..try before and after.. uncomment the messagebox.show, if the method is being exposed to the client (I think) youll get a message box as you step yourself through the form..some forms don't show anything, which makes it tough..
Private Sub oTrans_adapter_BeforeAdapterMethod(ByVal sender As object, ByVal args As BeforeAdapterMethodArgs) Handles oTrans_adapter.BeforeAdapterMethod
'MessageBox.Show(args.MethodName) ' use this to find method
Most of the event handlers from the wizard give you some clues about checking for events.. like the epiviewnotification (the fire hose) you could try messagebox.show (args.notifytpe)
HTH
Rob Bucek
FAX: (715)284-4084
[Description: cid:1.234354861@...]<http://www.dsmfg.com/>
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of tkoch77
Ted
I did that, and the only one I am able to get a messagebox to show up when clicking through the tree nodes is with EpiViewNotification, message box appears saying initialize. The only problem with this is there is no AFTER EpiViewNotification. I am trying to update a datagrid I have on a tab, and it keys off what is in the job fields on that form. So after the new information is loaded into the form i want to use that information to update the datagrid.
I tried using this but it uses what is in the form prior to the EpiViewNotification updating the UI.
Private Sub edvSugPoDtl_EpiViewNotification(ByVal view As EpiDataView, ByVal args As EpiNotifyArgs)
         Search()
      End If
End Sub
HTH
Rob Bucek
FAX: (715)284-4084
Ted
Useful links for the Yahoo!Groups Vantage Board are: ( Note:Â You must have already linked your email address to a yahoo id to enable access. )
(1) To access the Files Section of our Yahoo!Group for Report Builder and Crystal Reports and other 'goodies', please goto: http://groups.yahoo.com/group/vantage/files/.%c2%a0
I thought I remember reading another post about capturing where the focus was on the tree... if you could do that then maybe you could refresh or notify the form, or even your embedded dashboard (if that's what your grid is..) that code would be beyond my experience though.
Rob Bucek
FAX: (715)284-4084
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Ted Koch
Search()
End If
End Sub
To: "vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>" <vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>>
HTH
Rob Bucek
FAX: (715)284-4084
[Description: cid:1.234354861@...<mailto:1.234354861%40web65412.mail.ac4.yahoo.com>]<http://www.dsmfg.com/>
From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>] On Behalf Of tkoch77
Ted
(1) To access the Files Section of our Yahoo!Group for Report Builder and Crystal Reports and other 'goodies', please goto: http://groups.yahoo.com/group/vantage/files/.<http://groups.yahoo.com/group/vantage/files/>
Thanks for the input Rob, I'll keep trying different ways until I get it.
Rob Bucek
FAX: (715)284-4084
      Search()
    End If
End Sub
HTH
Rob Bucek
FAX: (715)284-4084
Ted
You should be able to use the EpiView. The data you need should be visible
> Rob Bucek
> FAX: (715)284-4084
> Of Ted Koch
> Search()
> End If
> End Sub
> method
> HTH
> Rob Bucek
> FAX: (715)284-4084
> tkoch77
> something?
> Thanks,
> Ted
*John Driggers*
**:: 904.404.9233*
*:: waffqle@...*
*:: NO FAXES*
Not not seeing it, when it is being triggered I'm getting the data before the initialize has completed, not what is on the screen after. I dont know if you have time, but if you try this you can see what is happening.
         dim txtAsmSeq as epiNumericeditor = Ctype(csm.GetNativeControlReference("5621d1ff-7728-456c-a3c4-724b67b69cbc"), epinumericeditor)
      End If
   End Sub
> Rob Bucek
> FAX: (715)284-4084
> Of Ted Koch
>Â Â Â Â If (args.NotifyType = EpiTransaction.NotifyType.Initialize) Then
>Â Â Â Â Â Â Search()
>Â Â Â Â End If
> End Sub
>Â Â Â Â Â Â Â Â Private Sub oTrans_adapter_BeforeAdapterMethod(ByVal
>Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â '// ** Argument Properties and Uses **
>Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â '// args.MethodName, args.Cancel
>Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â 'Add Event Handler Code
>Â Â Â Â Â Â Â Â Â Â 'MessageBox.Show(args.MethodName) ' use this to find
> method
>Â Most of the event handlers from the wizard give you some clues about
> HTH
> Rob Bucek
> FAX: (715)284-4084
> tkoch77
> something?
> Thanks,
> Ted
*John Driggers*
**:: 904.404.9233*
*:: waffqle@...*
*:: NO FAXES*
of the control.
> epinumericeditor)
> End If
> End Sub
> grid
> > Rob Bucek
> > FAX: (715)284-4084
> > Of Ted Koch
> when
> AFTER
> and
> > Search()
> > End If
> > End Sub
> > method
> > HTH
> > Rob Bucek
> > FAX: (715)284-4084
> > tkoch77
> trigger
> > something?
> > Thanks,
> > Ted
> *John Driggers*
> **:: 904.404.9233*
> *:: waffqle@...*
> *:: NO FAXES*
*John Driggers*
**:: 904.404.9233*
*:: waffqle@...*
*:: NO FAXES*
of the control.
>Â Â Private Sub edvSugPoDtl_EpiViewNotification(ByVal view As EpiDataView,
>Â Â Â Â ' ** Argument Properties and Uses **
>Â Â Â Â Â Â dim txtAsmSeq as epiNumericeditor =
> epinumericeditor)
>Â Â Â Â Â Â msgbox(txtasmseq.text)
>Â Â Â Â End If
>Â Â End Sub
> grid
> > Rob Bucek
> > FAX: (715)284-4084
> > Of Ted Koch
> when
> AFTER
> and
> >Â Â Â Â End If
> > End Sub
> > method
> > HTH
> > Rob Bucek
> > FAX: (715)284-4084
> > tkoch77
> trigger
> > something?
> > Thanks,
> > Ted
> *John Driggers*
> **:: 904.404.9233*
> *:: waffqle@...*
> *:: NO FAXES*
*John Driggers*
**:: 904.404.9233*
*:: waffqle@...*
*:: NO FAXES*
