I feel like I spend most of my life on this website now…
I recently created this BPM form to show my BAQ. Originally, I had this named IndentedBOM, but now my company wants our naming scheme to be DA-IndentedBOM, or to include our company initials before everything.
The code worked fine before, but now when I am copying it over and renaming things, I am getting this error.
It looks like it is separating out the name of my form and I am not sure why.
If I try changing it to anything else I get this error.
Not sure where to go from here.
Doug.C
(Doug Crabtree)
January 17, 2023, 8:52pm
3
Can you post your code inside a codeblock for us to review? At least the portion you renamed?
Of course! No secrets here and its not that big anyways.
// Custom code for IP_DA-IndentedBOM
// Created: 1/17/2023 2:11:16 PM
using System;
using System.ComponentModel;
using System.Data;
using System.Diagnostics;
using System.Windows.Forms;
using System.Collections;
using System.Collections.Generic;
using Ice.BO;
using Ice.UI;
using Ice.Lib;
using Ice.Adapters;
using Ice.Lib.Customization;
using Ice.Lib.ExtendedProps;
using Ice.Lib.Framework;
using Ice.Lib.Searches;
using Ice.UI.FormFunctions;
public class Script
DynamicQueryAdapter dynamicQueryAdapter;
EpiTextBox myPartSearchTextBoxIsSoFancy = null;
this.PartSearch.Click += new System.EventHandler(this.PartSearch_Click);
myPartSearchTextBoxIsSoFancy = (EpiTextBox)csm.GetNativeControlReference("a49758c5-2a32-4706-a5e2-ab47c27805f4");
this.GoButton.Click += new System.EventHandler(this.GoButton_Click);
dynamicQueryAdapter = new DynamicQueryAdapter(IP_DA-IndentedBOM);
dynamicQueryAdapter.BOConnect();
this.GoButton.Click -= new System.EventHandler(this.GoButton_Click);
// Begin Custom Code Disposal
this.PartSearch.Click -= new System.EventHandler(this.PartSearch_Click);
dynamicQueryAdapter.Dispose();
// End Custom Code Disposal
private void PartSearch_Click(object sender, System.EventArgs args)
object ret = ProcessCaller.InvokeAdapterMethod
(oTrans.EpiBaseForm, "QuickSearchAdapter", "ShowQuickSearchForm", new object[]
{oTrans.EpiBaseForm, "PartSearch", false/* multi-select */, new DataTable() });
// user cancelled
if (ret == null) return; //This is a short circuit. If no value was returned, exit method.
myPartSearchTextBoxIsSoFancy.Text = (String)ret;
private void GoButton_Click(object sender, System.EventArgs args)
if(myPartSearchTextBoxIsSoFancy.Text == "")
MessageBox.Show("Please Enter a Part Number");
}else{
RunBAQ();
private void RunBAQ()
string myPartNum = myPartSearchTextBoxIsSoFancy.Text;
QueryExecutionDataSet queryExecutionDataSet = new QueryExecutionDataSet();
queryExecutionDataSet.Tables["ExecutionParameter"].Rows.Add("PartNum", myPartNum, "nvarchar", false, null, "A");
dynamicQueryAdapter.ExecuteByID("DA-IndentedBOMBAQ", queryExecutionDataSet);
epiUltraGridC1.DataSource = dynamicQueryAdapter.QueryResults.Tables["Results"];
Doug.C
(Doug Crabtree)
January 17, 2023, 9:15pm
5
Looks like:
should be:
dynamicQueryAdapter = new DynamicQueryAdapter("IP_DA-IndentedBOM");
It needs quotes.
I believe I tried this, and it threw the third error. And it didn’t need quotes before either, so not sure why it matters now
Doug.C
(Doug Crabtree)
January 17, 2023, 9:47pm
7
That’s line 44 … so it’s thinking you’re subtracting two variables: IP_DA and IndentedBOM:
Sigh … I’m sorry …
Change it to this:
dynamicQueryAdapter = new DynamicQueryAdapter(oTrans);
